Points Gap
6 replies to this topic
#1 Guennie
Guennie
  • 186 posts
  • Local Club: Bury Mini Club
Posted 04 February 2008 - 01:35 PM
hey
sorry if this has been covered before, but i did do a search and couldn't find anything!
i need to replace the points on my mini while i'm at uni, but like an idiot i left my manuel at home. can someone please tell me what the gap between the points should be on an mg metro 1275. i'd do it on the dwell angle but dont have the equipment with me!.
cheers
Guennie
#2 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 04 February 2008 - 01:39 PM
I don't have a manual at the ready but most Lucas distributors I've ever worked with use a points gap of 0.015" or 0.016". Anything close to that will get you going and on the road. A lot of the old-timers I know (older than me) talk about setting the gap on the side of the road using a match-book cover as a feeler gauge. If that's close enough... I'm sure with feeler gauges you'll do much better.
#3 Guennie
Guennie
  • 186 posts
Posted 04 February 2008 - 01:42 PM
thanks a lot. i had a feeling that it was somewhere along those lines but wanted a second, more experienced opinion.
cheers
Guennie
#4 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 04 February 2008 - 01:50 PM
calibrated cigarette papers is what you need ;D
14 to 16 thou is good enough, of if you do get your hands on a dwell meter, 54 +- 5
#5 Big_Adam
Big_Adam
  • 7,435 posts
Posted 04 February 2008 - 02:11 PM
And for thoses in metric land the gap is:
0.35mm - 0.40mm
#6 Ethel
  • 25,919 posts
Posted 04 February 2008 - 02:14 PM
0.35mm - 0.40mm
They'd be the most useful figures if your Spanish friend is fitting them.
I knew it was too weak a joke but couldn't stop myself ;D - "i left my manuel at home"
every chance you're not the only one with metric feelers Adam, so it was good advice :w00t:
Edited by Ethel, 04 February 2008 - 02:49 PM.
#7 Big_Adam
Big_Adam
  • 7,435 posts
Posted 04 February 2008 - 02:40 PM
Handy for me, I don't have an imperial feeler blade set. Only have a metric one.
