Mig Welder
10 replies to this topic
#1 bentedder
bentedder
  • 193 posts
Posted 01 February 2008 - 05:39 PM
i am going to be doing some welding on my car soon is a 90 amp gasless mig welder enough to do the job?? or does anybody know where i can buy a cheap welder for under £160?
#2 Globule
Globule
  • 1,134 posts
Posted 01 February 2008 - 05:42 PM
It all depends what your welding i guess! personally i'd opt for a gas welder, just my personal opinion as there is less spatter and the wire is cheaper! of course you then have to buy gas etc :proud:
Generally people advise around a 140amp one, just so then it can take it if you need to weld a subby or anything heavy i'd imagine!
#3 In-a-mini
In-a-mini
  • 831 posts
  • Local Club: smag (southend mini action group)
Posted 01 February 2008 - 05:43 PM
machine mart do welders for not bad money they will probably be a clark one. Personaly i would use a mig welder with gas i find it alot nicer to work with
#4 bentedder
bentedder
  • 193 posts
Posted 01 February 2008 - 05:49 PM
im going to be doing mainly panel work on the body so anymore advice or websites welcome
#5 In-a-mini
In-a-mini
  • 831 posts
Posted 01 February 2008 - 05:53 PM
90 amp will be fine for body thicknes work even probably up to 2mm thick mild steel outer body is usually 1mm thick (20 guage)
http://www.machinema...diy-mig-welders
Edited by In-a-mini, 01 February 2008 - 05:55 PM.
#6 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,138 posts
  • Name: Sean
Posted 01 February 2008 - 06:31 PM
For car body work you need one that will go down to a min of 30amps. Gasless migs are generally considered to be useless!!
For your budget I would also recommend a clarke welder, SIP's are prone to feed probs.
I would include an auto darkening welding helmet in your budget as this will make your life a lot easier!!!
Also, unless you are only going to use it very infrequently it will eat the little cheap gas bottle you get. Far better and cheaper in the long run to get a gas account with some one like BOC, its not as expensive as you think.
For more advice check out
www.mig-welding.co.uk
Seamus
#7 pete1781
pete1781
  • 113 posts
  • Local Club: W.A.M.O
Posted 01 February 2008 - 08:59 PM
i bought a sip one off of ebay 140 amp turbo, £150, dead chuffed with it, first time i welded ever too and its pretty easy, not so easy to make it look good but i figure practice will make better, use it gasless with flux coated wire which i understand is more difficult than with gas but i've found it pretty easy and really enjoy it, also bought a cheapo auto darkening helmet, brilliant, best purchase to date, would deffo recommend it!! also should add that i've never had any problems with it feeding badly(well not since i put the feed wheel up the right way anyway :goaway: )hope this helps a little :proud:
Pete
#8 Monstrous
Monstrous
  • 889 posts
Posted 01 February 2008 - 10:34 PM
Managed to get a 130amp sealey welder off ebay brand new for £135 with gas bottle, wire, regulator, mask (rubbish, but a mask none-the-less) and spare tips
really nice welder, and not too hard to setup and use
definately recommend buying a auto-darkening mask, especially if it's your first time, trying to weld one handed when you can't see is a wee bit difficult :ph34r:
#9 mini_kel
mini_kel
  • 2,851 posts
  • Local Club: EMC/No pub mini club
Posted 01 February 2008 - 10:35 PM
My friend has a sealey 130 amp for sale nearly new no wheels though £170
#10 mini-mad-dan
mini-mad-dan
  • 467 posts
Posted 02 February 2008 - 10:10 AM
i use a 90 amp gassless mig welder and get very good results with it, but splatter can be a problem if the steel is very very very clean it is very minimal, i used it for body panels and the sills to very good effect.
#11 Broomer
Broomer
  • 1,771 posts
Posted 02 February 2008 - 10:48 AM
so have i, my gasless mig has been pretty good the whole time, yeah you get some splatter, just grind it back.
