Dwell Angle
7 replies to this topic
#1 NateDogg2909
NateDogg2909
  • 188 posts
  • Local Club: NottsAboutMinis
Posted 31 January 2008 - 10:39 PM
How do all,
Bloody car has been fine all year, it has its MOT then the dial reads 65666miles this week, and all goes tits up.
Im having ignition trouble, everything has been changed for the best, bar the points and condenser.
I have a 1990 Mini City E just wondering if anyone knows the model of dizzy and what the dwell angle should be. I have the meter but Haynes mite be wrong for the reading (not the first time i mite add).
Cheers everyone.
Nate
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 31 January 2008 - 10:43 PM
54 degress +- 5
any more information will depend on engine number...
#3 NateDogg2909
NateDogg2909
  • 188 posts
Posted 31 January 2008 - 10:47 PM
hold on let me run out and check it
nate
#4 NateDogg2909
NateDogg2909
  • 188 posts
Posted 31 January 2008 - 10:58 PM
Engine Number 99HE20
#5 cambiker71
cambiker71
  • 1,050 posts
  • Local Club: Cambscustomclassics.com
Posted 31 January 2008 - 11:05 PM
According to my Haynes book of lies, these are the angles depending on distributor type (and no i can't remember which of the Lucas ones look like which)
Lucas 23d4 and 25d4.................60 degrees +/- 3
lucas 45d4:
non-sliding contacts...................51 +/- 5
sliding contacts.........................57 +/- 5
Ducellier...................................57 +/- 2 degrees 30 minutes
Hope this helps
#6 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 01 February 2008 - 08:17 AM
Details for 99HE20....
Idler speed 750+- 50
Fast Idle 1100 +- 50
Timing (strobe set @ 1500rpm) 10 deg btdc
Dizzy Lucas 59D4 ( model 41907 )
Dwell 54 +- 5
CB gap 14thou to 16thou
#7 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 01 February 2008 - 01:04 PM
Educate me please. When did the Mini switch to electronic ignition? I'm surprised Rover was still using points in 1990.
#8 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 01 February 2008 - 02:22 PM
I believe the 998 used points until the end, only the 1275 mini had a leccy dizzy... in carbed form, and then obviously with the SPi the dizzy became just a shell with wires attached and eventually lost altogether with the MPI .
Just had a look at the Metro book, and even that says the 998 never got a leccy dizzy... only the 1275's
Edited by GuessWorks.co.uk, 01 February 2008 - 02:26 PM.
