This is a good little program, go on this site http://www.turbo-bike.net/ and download the turbo calculator, it's made for motorbikes but i can't see it being a problem using it for a car.
It has the following:
Garret, Mitsubishi and IHI maps flow maps
Calculate: how much air you need from your Turbo
In cf/m, lb/min and m^3/m
Calculate: How much boost your engine can handle
Calculate: Air temperature after turbo
Calculate: Engine VE = Engine Volumetric Efficiency
Calculate: Injector size
Calculate Compression Ratio
Calculate: Gear Ratio (Speed)
Conversion from Psi to Bar and bar to Psi and more
Turbo Calculator
mini_turbo_pete
, Jan 31 2008 01:00 PM
1 reply to this topic
