can anyone send me a diagram of the su carb.need a break down of it......cheers.wils(haynes?)
Su Carb
wilsey07
, Jan 24 2008 11:25 AM
4 replies to this topic
Posted 24 January 2008 - 11:25 AM
Posted 24 January 2008 - 11:28 AM
which one?
Posted 24 January 2008 - 11:29 AM
Ermmm.....buy a haynes. It's in the there.
Posted 24 January 2008 - 12:49 PM
HS SERIES CARB
1 Body
2 Piston lifting spring
3 Spring for pin
4 Sealing washer
5 Plain washer
6 Circlip
7 Suction chamber
8 Suction chamber screw
9 Piston
10 Spring
11 Jet needle with collar
12 Needle spring
13 Needle guide
14 Needle guide - locking screw
15 Piston damper
16 Damper sealing washer
17 Throttle adjusting screw
18 Spring for screw
19 Float-chamber
20 Float chamber gasket
21 Float
22 Float hinge pin
23 Float chamber lid
24 Needle & seat
25 Baffle plate
26 Float chamber lid screw
27 Spring washer
28 Float chamber securing bolt
29 Spring washer
30 Plain washer
31 Throttle spindle
32 Throttle disc
33 Throttle disc screws
34 Throttle spindle washer
35 Throttle return lever
36 Fast idle screw
37 Spring
38 Throttle spindle lock nut washer
39 Throttle spindle nut
40 Jet assembly
41 Jet assembly sleeve nut
42 Washer
43 Gland
44 Ferrule
45 Jet bearing
46 Skid washer
47 Jet lock nut
48 Spring
49 Jet adjusting nut
50 Pick-up lever assembly
51 Pick-up lever link
52 Lever to jet securing screw
53 Pivot bolt
54 Pivot bolt tube--inner
55 Pivot bolt tube--outer
56 Distance washer
57 Cam lever
58 Washer
59 Cam lever spring
60 Pick-up lever spring
61 Piston guide key
62 Key securing screw
63 Piston lifting pin-alternative
64 Float chamber spacer
HIF SERIES CARB
1 Jet bearing washer
2 Jet bearing
3 Jet bearing nut
4 Jet assembly
5 Lifting pin
6 Lifting pin spring
7 Circlip
8 Adjusting screw seal
9 Jet adjusting screw
10 Bi-metal jet lever
11 Jet spring
12 Jet retaining screw
13 Needle seat washer(if required)
14 Float needle seat
15 Float needle
16 Float
17 Float pivot
18 Pivot seal
19 Float chamber cover seal
20 Float chamber cover
21 Spring washer
22 Cover screw
23 Piston damper
24 Damper washer
25 Suction chamber
26 Chamber screw
27 Identity tag
28 Piston
29 Jet needle
30 Needle guide
31 Piston spring
32 Needle retaining screw
33 Needle spring
33 Needle spring
34 Throttle spindle seal
35 throttle disc screw
36 Throttle spindle
37 Throttle disc
38 Throttle spindle seal
39 Throttle actuating lever
40 Fast idle screw & nut
41 Throttle lever
42 Throttle adjusting screw & nut
43 Tab washer
44 Retaining nut
45 Throttle spring
46 Body
47 Choke assembly gasket
48 Choke spindle
49 Choke 'O' seal
50 Choke body
51 Spindle seal
52 End cover
53 Retaining plate
54 Choke return spring
55 Retaining screw
56 Fast idle cam
57 Tab washer
58 Retaining nut
There you go
requesting pin?
1 Body
3 Spring for pin
4 Sealing washer
5 Plain washer
6 Circlip
7 Suction chamber
9 Piston
10 Spring
12 Needle spring
13 Needle guide
15 Piston damper
18 Spring for screw
19 Float-chamber
21 Float
22 Float hinge pin
24 Needle & seat
25 Baffle plate
27 Spring washer
29 Spring washer
30 Plain washer
31 Throttle spindle
32 Throttle disc
36 Fast idle screw
37 Spring
40 Jet assembly
42 Washer
43 Gland
44 Ferrule
45 Jet bearing
46 Skid washer
47 Jet lock nut
48 Spring
53 Pivot bolt
56 Distance washer
57 Cam lever
58 Washer
59 Cam lever spring
61 Piston guide key
HIF SERIES CARB
2 Jet bearing
3 Jet bearing nut
4 Jet assembly
5 Lifting pin
7 Circlip
11 Jet spring
15 Float needle
16 Float
17 Float pivot
18 Pivot seal
21 Spring washer
22 Cover screw
23 Piston damper
24 Damper washer
25 Suction chamber
26 Chamber screw
27 Identity tag
28 Piston
29 Jet needle
30 Needle guide
31 Piston spring
33 Needle spring
33 Needle spring
36 Throttle spindle
37 Throttle disc
41 Throttle lever
43 Tab washer
44 Retaining nut
45 Throttle spring
46 Body
48 Choke spindle
49 Choke 'O' seal
50 Choke body
51 Spindle seal
52 End cover
53 Retaining plate
55 Retaining screw
56 Fast idle cam
57 Tab washer
58 Retaining nut
There you go
requesting pin?
Posted 27 January 2008 - 08:32 PM
ermmmm...cheers!!Ermmm.....buy a haynes. It's in the there.
