Gearbox Bearing Numbers
4 replies to this topic
#1 Mart!
Mart!
  • 303 posts
  • Local Club: www.MainlyMinisMontreal.com
Posted 21 January 2008 - 08:26 PM
i'm trying to find the bearing numbers so that i can purchase them at my local bearing supplier instead of ordering them from a mini shop. some have the number stamped on them, but some dont, and these are the ones i'm looking for. my gearbox is a 4 sync pre-verto, "A".
here's what i have so far, first number is the mini part number.
AAU1815 - none stamped - 1ST GEAR BEARING (DOUBLE ROW)
ADU7619 - 3MDJT1G RHP or 2/MJ28.5 - 1ST MOTION (LARGE)
AAU8424 - 1/LRJ15.8 - (SUPPORT BEARING - 1ST MOTION, OUTER)
AAU1816 - none stamped - 2ND/3RD BEARING
AAU1365 - 15MJ1-1/8 RHP - BIG DOUBLE ROLLER
13H7848 - SCH1212 OR JHD1212 - IDLER GEAR
88G396 - none stamped - LONG LAYGEAR BEARING
CHM172 - none stamped - PILOT BEARING
CHM141 - none stamped - SHORT LAYGEAR BEARING
AHU1856/MS - 4/LJT34.9 - DIFF output shaft BEARINGS
can anybody help?
thanks
#2 Mart!
Mart!
  • 303 posts
Posted 22 January 2008 - 06:19 PM
nobody knows?
#3 [email protected]
[email protected]
    Minispares
  • Minispares
  • 3,229 posts
  • Name: Simon Jackson
Posted 22 January 2008 - 07:21 PM
AAU1815 and 16 are specific Mini gearbox bearings, you won't find them at a bearing specialist, at least not easily.
#4 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 22 January 2008 - 07:49 PM
I wouldn't bother, but give it a try....
I tried to get the bearings locally from a RHP supplier, the spigot bearing which is about £10 from mini specialists, they were wanting over £40 not including vat, but I can get you the numbers (RHP)
Double roller 1/MDJT25.4N
Single roller 2/MJ28.5
Diff bearings LJ1.3/8J
1st Motion Spigot bearing 1/LRJ15.8
All the rest are pretty much specific to the mini gearbox, it's probably just as cheap buy them in the UK and get them sent over ( as I've just seen you're in Canada )
#5 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 22 January 2008 - 08:46 PM
Mart, I posted a reply for you on the Coopertune site. Paraphrasing it here, I had no luck when I went to my bearing supply house with carefully measured bearings. I did find some NOS parts at MiniSport for my 3-synchro gearbox.
