Elemental Designs?
#61
Posted 16 March 2008 - 08:31 AM
If the hole is too small then you could always get/make a packing ring from MDF to raise the speakers up a little.
#62
Posted 16 March 2008 - 06:14 PM
#63
Posted 25 March 2008 - 09:31 PM
Think the only way of getting them in without damaging anything would be to take them apart and reassemble them in place. ie unscrew the magnets.
#64
Posted 26 March 2008 - 06:58 PM
#65
Posted 26 March 2008 - 07:05 PM
i was going to put them in the shelf but decided a subwoofer in the parcel shelf isnt the best idea as the boot is far from sealed and could possibly end up sounding poor in comparsion to a properly sized and sealed enclousure. the rear bench makes for a perfect place as it can be sealed if needed. post up some pics if you manage to get em fitted.
Edited by THedooBZ, 26 March 2008 - 07:06 PM.
#66
Posted 26 March 2008 - 07:09 PM
#67
Posted 26 March 2008 - 10:57 PM
#68
Posted 27 March 2008 - 08:36 AM
redhotmini, have you actually got them in the back shelf?
i think u misunderstood,, he tried to fit them in the rearshelf but couldnt so opted for under the rear bench like myself..
on the otherhand iv had a play with mine and think it would be possible if you placed them slighty closer together?? as for clearance on the petrol tank an mdf ring would work however im unsure on how you would fit the sub as its tight against the window as it stands,, move it up half an inch and i think u will be stuck,
is there no way you would consider under the bench method??? i fibreglassed mine in last night and so should be able to connect some juice to it today to see how it sounds, also need to get a load of wadding from somewhere so i think ill just get some cheap pillows and rip them apart.
also the hole diameter i used was 5 and 3/4 inch,, this allowed the sub to drop styraight in and the terminals to clear aswell. get some photos!!!
#69
Posted 29 March 2008 - 04:21 PM
#70
Posted 29 March 2008 - 04:55 PM
#71
Posted 29 March 2008 - 07:15 PM
http://www.theminifo...x...59707&st=90
pictures are on the last page i think..
i dont have anyone in the back as you cant physically get in due to my seats being so far back as i like my legroom so not having grills isnt a problem, granted if passengers are in the rear you would want some sort of grill on them.
#72
Posted 01 April 2008 - 09:47 AM
#73
Posted 07 April 2008 - 06:26 PM
#74
Posted 07 April 2008 - 06:59 PM
#75
Posted 08 April 2008 - 08:44 AM
As for your thermal meltdown, I suggest cooling fans. You can pick them really cheap on ebay, ones designed for pc cases work well. Something to look into!
