Indicator Stalks
Posted 16 January 2008 - 08:49 AM
At what point are they scrap? The indicators still work, but I cant seem to get the horn or headlight flasher to work. I know thay are on the same cirucit and am checking, but just thinking ahead...
Posted 16 January 2008 - 10:36 AM
Posted 16 January 2008 - 10:49 AM
But that does make them quite repairable too.
Posted 16 January 2008 - 01:34 PM
The stalk is close to £45 from Mini spares ... They are fixable but you need 3 pairs of hands and are very very fiddley. and be carefull as you take it apart as the springs shoot out and can easily be lost for a lifetime. lol
I presume it will be just a wire thats come loose if its the Horn and the Full beam flasher
Posted 16 January 2008 - 02:02 PM
I had a problem with my indicator stalk ..... There is a small ball bearing and Copper pin that kept dropping out due to a very small crack in the plastic causing the springs to force the mechanism apart and pin to move!
The stalk is close to £45 from Mini spares ... They are fixable but you need 3 pairs of hands and are very very fiddly. and be careful as you take it apart as the springs shoot out and can easily be lost for a lifetime. lol
That'll be it: £20 for the stalk 'n £25 for the large collection of springs 'n ball bearings shot around the Lucas factory
Do a continuity test on the connector block, across the appropriate switch contacts before to rip it to bits.
Posted 16 January 2008 - 09:09 PM
Agreed.I tried repairing the stalk on my 205 when the horn switch stopped working.It was like trying to squeeze an octopus into a matchbox.In the end I managed to get all bar the headlights working and drove to the breakers during daylight.Turned out to be the earth on the horn itself.Do a continuity test on the connector block, across the appropriate switch contacts before to rip it to bits.
Posted 16 January 2008 - 09:30 PM
Posted 16 January 2008 - 10:12 PM
else we would still be waving our hands out the window all the time
I got one the other day too
x
Posted 17 January 2008 - 09:20 AM
Posted 14 April 2016 - 09:45 PM
Does anyone have a pic to show where all teh springs etc go?
Posted 15 April 2016 - 07:59 PM
Floor, wall, coffee cup and eye generally!
I think they're called 'Jesus-Springs' normally since that's what you scream as they go pinging over your shoulder or in your face !
Posted 15 April 2016 - 08:08 PM
Yep.. Op when the stalk drops and you have no clue where it all belongs..Floor, wall, coffee cup and eye generally!Does anyone have a pic to show where all teh springs etc go?
