Dashboard Directory
1156 replies to this topic
#856 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 29 June 2013 - 09:01 AM
Yh the carbon dash has been sold out for ages :(
Not true!  I got mine easily and no word of low stocks.
#857 Carlsmini
Carlsmini
  • 337 posts
Posted 29 June 2013 - 09:29 AM
Really?? Says sold out on website..
http://www.somerford...oducts_id=15361
I'll give them a call then :)!
#858 thelegg
thelegg
  • 608 posts
Posted 02 July 2013 - 10:22 PM
Heres My Dashboard and center console with my own custom design clock faces :)
Attached File  IMG-20130626-00921.jpg   74.95K   189 downloads  Attached File  IMG-20130626-00922.jpg   74.39K   110 downloads
#859 craigr91
craigr91
  • 429 posts
  • Local Club: nwminiclub
Posted 19 July 2013 - 01:51 PM
I do like that.... But it's not for me, good work though :)
#860 thelegg
thelegg
  • 608 posts
Posted 19 July 2013 - 08:59 PM
Cheers :)
#861 munkey26
munkey26
  • 267 posts
Posted 20 July 2013 - 05:19 PM
Standard MPi dashboard re-finished properly to Rolls Royce / Bentley Standards by ex works staff using the same wood as used on current Rolls.
I can get these done if yours has the dreaded water marks.
PM if you're interested
PS sorry for the not great pics
#862 thelegg
thelegg
  • 608 posts
Posted 20 July 2013 - 10:24 PM
looks good but some better pics would really do it some justice :)
#863 mini_mentalist_chris
  • 137 posts
  • Local Club: S.L.M.O.C.
Posted 24 July 2013 - 09:32 PM
I am currently trying to design the dashboard for my car. Is there a law regarding the type of dashboard switches used on later minis (mine is a '94)? I say this because I heard that rocker switches replaced toggle switches for crash safety reasons. I am looking to build a racing style fibreglass dashboard and would have liked to include toggle switches in the design, if this would cause implications I will use the flick up cover switches like on the starter button I am planning to use.
#864 thelegg
thelegg
  • 608 posts
Posted 25 July 2013 - 08:57 PM
i dont think theres any law as to what type of switches you can use ????? just what ever looks good and fits i guess :)
#865 MINI MAD RKH
MINI MAD RKH
  • 308 posts
  • Local Club: DCMOC
Posted 28 July 2013 - 01:19 PM
... 2 days later & finally got to the end of the thread :lol:
Some fantastic looking dashes in here :D
Just about to start one myself as the one that came with the car is utter pants!!  :unsure:
That's brilliant/mad/brilliant :lol:
again, not for me but I made some doorcards out of similar blk fur for my 1275GT back in the 90's :D
how did you do the faces??
Edited by MINI MAD RKH, 28 July 2013 - 01:20 PM.
#866 thelegg
thelegg
  • 608 posts
Posted 29 July 2013 - 07:13 PM
i made the designs myself and then sent them off to this company  http://www.heagren.com/gallileo/ to have them printed, then its just a case of taking the clocks apart n swapping the faces over although getting the needles off is a hard job so i cheated n cut the hole bigger so the needle would pass through :D
#867 stealth05
stealth05
  • 625 posts
Posted 30 July 2013 - 04:50 AM
mine fitted
#868 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 01 August 2013 - 05:22 AM
Dash project....
now flocked....parts going in....
White faces and backlit dials....
579575_10153130401090647_1158998324_n.jp
179707_10153130401435647_1903223841_n.jp
Re routed some of the wires, added length to the wiring for dashboard so i can connect it up easily and fix into place. Also means dash can be removed and pulled forward should there be any reason to get behind dash.
264479_10153130402645647_2004433007_n.jp
Dash in place....not finished.....speedo dials need trim around, need green lenses for indicators etc.
556306_10153130403195647_1476752687_n.jp
Testing the electrics....
Nice semi flat surface, similar to a modern car...
943710_10153130404050647_1018322157_n.jp
Speedo lit up picture.......can be either green or blue....
Awaiting vacuum gauge + longer screws for NS speaker and it can all be fitted properly. Need to run in the vac hose and oil pressure pipe aswell once its all somewhere near to measure up.
#869 mrbridger
mrbridger
  • 422 posts
  • Local Club: no
Posted 02 August 2013 - 10:16 PM
Just finished my new fascia...Black vinyl over aluminium.
It took a couple of days worth of measuring and whittling to get right. One of the most challenging aspects was getting the piece which will join the fascia and centre binaccle measured up and shaped.
All gauges by Smiths and will be operational as opposed to ornamental.
Just waiting on a Smiths 80mm Tacho to fill the gap.
***Took an absolute age to find those rare, 'Oil Check' and 'Fasten seat belt' gauges.
Edited by mrbridger, 03 August 2013 - 07:43 PM.
#870 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,724 posts
  • Name: Chris
  • Local Club: None
Posted 03 August 2013 - 09:34 AM
how does the oil check one work?? is it just like a low oil light type thing??
    Google (1)
