Dashboard Directory
1156 replies to this topic
#481 mattista
mattista
  • 198 posts
  • Local Club: looking for a club
Posted 28 May 2010 - 08:01 PM
Matilda's is standard walnut, but with a centre console to stop my packed lunch from wedging itself beneath the clutch pedal. :blink:
could anyone please tell me what steering wheel that is ?? thanks matt
#482 rusky
rusky
    Banned due to discrepencies in Classifieds
  • 53 posts
Posted 06 June 2010 - 09:52 AM
Matilda's is standard walnut, but with a centre console to stop my packed lunch from wedging itself beneath the clutch pedal. :D
its the mpi airbag steering wheel can find the outer rim in diffrent colours
#483 meanie
meanie
    Just On Tickover
  • 8 posts
  • Local Club: minisvenclubnetherlands
Posted 06 June 2010 - 06:31 PM
Here's mine, all standard (except for the "Mini" badge I stuck on the glovebox)...
a glovebox orginal in a mini?
where or what typ of mini does this come from??????????
and is it also available for the other side ??
#484 davey123a
davey123a
  • 38 posts
Posted 07 June 2010 - 07:45 PM
fuc***ing amazing dash looks brilliant at night with the lights on
#485 Banni
Banni
  • 22 posts
Posted 13 June 2010 - 09:14 PM
as seen on Retro Retrims!
:D
That is amazing, stupid question but can you put one of these early dashboards on a later car, ie my 1988 Mini City E?
Cheers :D
#486 rosalind
rosalind
  • 22 posts
Posted 19 June 2010 - 12:36 PM
Hi - sorry for using my wifes account! (I am her husband) I am in the process of making her a dashboard, centre console and armrest that fit in with the look of her 1986 mini mayfair. It has Brown Interior...now what do you do with that!
The answer is a sheet of 12mm mdf, an old brown leather sofa, a scrap Rover 800 (for the dials) a scrap Vauxhal Omega (for the auto shift gator) and a sheet of vinyl.
We are pretty happy with the result. I am going to change the black self adhesive vinyl though - it looks like Fablon.
As its an auto mayfair I had to cut a different shape hole than the manual.
Darren
Attached File  rosalinds_console.jpg   74.69K   170 downloads
#487 minimad01
minimad01
  • 563 posts
Posted 20 June 2010 - 10:51 PM
That looks awesome. Suits the car by the looks of it with it being chopped an all.
Whats happened to the car if you dont mind me asking?
does anyone know how this dash is fixed in as i want to do it in my car ??
#488 garrett3
garrett3
  • 1,412 posts
Posted 22 June 2010 - 09:55 PM
I fitted it with stainless alan blots along the top and made some L shape brackets that came off the lower dash rail to the side of the KA dash and one from the heater to the dash.
Shown the the finished picture you can see the three in a row along the top (same both sides) and you can see the singular one on the side from the dash rail L bracket
Kept it simple. :D
Edited by garrett3, 22 June 2010 - 09:56 PM.
#489 minimad01
minimad01
  • 563 posts
Posted 23 June 2010 - 09:52 AM
brill thanks for replying looks very nice by the way :(
#490 h4wx1e
h4wx1e
  • 553 posts
  • Local Club: sutton mini club
Posted 23 June 2010 - 09:57 AM
just another idea about fixing, i did mine by glassing them bolts to the under side of the dash and fixing them through holes in the top dash rail then as garret said fixed the radio housing part to my heater and the sides to l shaped brackets above the footwell.
#491 SpyII
SpyII
  • 26 posts
  • Local Club: Mini Owners Club South Africa
Posted 25 June 2010 - 04:59 PM
Does anyone know if the following Dashboard would fit in the classic Mini ... 2010 Daihatsu Charade / Cuore?
#492 Foxy10
Foxy10
  • 387 posts
  • Local Club: Crewe's Missiles
Posted 25 June 2010 - 08:03 PM
has anyone got the template for the dashboard that you dont need the top dash rail like this one:
(sori 4 whoevers picture that is. hope u dnt mind)
cheers
Edited by Foxy10, 25 June 2010 - 08:04 PM.
#493 delboyeire
delboyeire
  • 65 posts
Posted 30 June 2010 - 12:53 AM
okay so im about to make my own dash but a havent got a clue what i'v to do with the clocks,iv got the origanal 2 clock set up how do i make the housing for them?any help appreciated :thumbsup:
#494 Down&Out
Down&Out
    The King Of Retro Cool
  • 4,850 posts
Posted 06 July 2010 - 12:18 AM
*Image*
*Image*
*Image*
Could be anything, bolts, screws, rivnuts etc.
If you want to do that in your car your going to need fibreglassing skills, and the ability to chop it right and in the right place.
If you have that kind of skill then how its fixed should be common sense and shouldnt require asking in here.
#495 garrett3
garrett3
  • 1,412 posts
Posted 06 July 2010 - 09:46 AM
*Image*
*Image*
*Image*
No fibreglassing with my dashes.
The dashes are cut down and "welded" back together using a soldering iron and small slithers of dash offcuts.
The dashes are then sanded and sent away to be flocked to get a nice even factory finish.
No glue, no fibreglass, no wood screws etc are needed, anyone can do it and its worth having a go.. the dashes cost about £40 from a scrappy and if you get it wrong you can just cut it and have another go.
No complicated measurements were taken, I just cut it in half and mounted the larger section, I then offered up the remaining section and noted where I needed to cut it.
Once cut I then joined the two and started to look at ways of making sure it all fit together cleanly by fitting and removing parts and heating with a hot air gun untill the shape was right.
No great skills needed :teehee:
Good luck if you have a go and keep us updated with pictures.
