Sprint Shell Fibre Glass Mk1 Rebuild - Shell now for sale
243 replies to this topic
#226 arris
arris
  • 80 posts
  • Local Club: Will be when its on the road
Posted 26 October 2009 - 12:28 PM
Can not wait to see this finished looks amazing, just wondering if you knew the inside measurement from the floor to the roof?
#227 mini-man-dan
mini-man-dan
  • 2,684 posts
  • Local Club: J19 Mini Owners Club
Posted 26 October 2009 - 12:47 PM
Hi
Are you doing them templates for my Dad to make them into polycarbonate versions? If so, you'd only need to do one side, as they should be identical but opposite (if you see what I mean...) from side to side.
Might make life a bit easier! >_<
Dan :lol:
#228 Dosy
Dosy
  • 78 posts
Posted 31 October 2009 - 10:06 PM
Can I ask how you will mount the shock absorbers on the front? I noticed there are no mounts on the outside of the inner wing like on a normal shell...
#229 CharlieBrown
CharlieBrown
  • 6,587 posts
Posted 02 November 2009 - 01:05 PM
No idea, but I will try and remember to measure it next time. Although I'm 6 foot and as long as the seat is mounted to the floor I've still got headroom.
Hi
Might make life a bit easier! :D
Dan :(
Yes. As for just one side indeed that is true. :D (I may have got slightly carried away but I wanted to double check that they are the same, its a bit tricky to judge it by eye.)
That Sir, is a very good point! I've not quite come up with a solution yet but I think the addition of some metal work to the subframe may be in order.
I was thinking coming off the subframe and bolted onto the bulkhead with most of the support coming from the subframe. Still to sort the details/design though.
Any ideas welcome. :wub:
#230 Ethel
  • 25,821 posts
Posted 02 November 2009 - 01:41 PM
The shockers on my plaggy car were mounted the same as on a steel Mini. The bracket bolts in to a little steel bar inside the bulkhead cross member. It's very fiddly, but you can fit it through the subby bolt hole. It's only 4 x 1/4" bolts.
#231 CharlieBrown
CharlieBrown
  • 6,587 posts
Posted 02 November 2009 - 05:07 PM
Any pics of that?
The issue is that there is no fibreglass where the shocks are to mount so it will need a plate of some kind at the very least. The question is if I weld it onto the subframe or just mount it off the body.
Personally using the subframe as well as the body seems the best idea.
#232 pete
pete
  • 680 posts
Posted 02 November 2009 - 07:35 PM
Charlie, have you checked the regs in the IVA manual regarding windows. All must be "e" marked.
Extract from IVA manual:
4.
All other windows (including sunroofs and removable glass panels) and side-screens must be “Safety Glazing” (which may be made from glass, or from plastic) and display the relevant markings. (see notes 2,3 and table 1)
Note 2: “Safety Glazing” made from glass must be so constructed or treated that if fractured it does not fly into fragments likely to cause severe cuts. Each piece of glass must display the following relevant permanent marking applied by the glass manufacturer.
ECE Regulation 43
Note 3: “Safety Glazing” made from plastic means material which is so constructed or treated that if fractured it does not fly into fragments likely to cause severe cuts. “Safety glazing” made from plastic must have an “e” mark applied by the material manufacturer.
#233 Saxo-Fiesta-Mini
Saxo-Fiesta-Mini
  • 2,889 posts
  • Local Club: LCMOC
NICE WORK me likely :D
#234 CharlieBrown
CharlieBrown
  • 6,587 posts
Posted 04 November 2009 - 10:36 PM
Hi Pete,
Yes that does ring a bell. Hmmm that might be an issue. I best do some research. Thanks for the pointer!!
#235 998dave
998dave
    998cc's Of Dave Goodness
  • 4,566 posts
  • Name: Dave
Posted 03 February 2010 - 12:21 PM
Time for another update Charlie?
Dave
#236 rob#155
rob#155
  • 268 posts
Posted 03 February 2010 - 01:22 PM
Hi Pete,
dunno if its any help mate, but i used to work in the glass trade and we supplied Laminated glass cut to size, now this laminated glass met the standards (cant remember the number!) so it was safe to use in "any rearward or sideways facing motor vehicle window" so basically any window but the screen. Also once we had cut it to size we acid etched the kitemark onto it in the corner.
So what I'm trying to say is that it may be worth visiting a good glass supplier, could work out not too expensive :)
Just a thought mate!
#237 george91
george91
  • 883 posts
Posted 03 February 2010 - 11:54 PM
Nice project, its deffinatly something a bit different, it looks lower or is it just me? Great stuff so far, any updates?
George
#238 advantage998
advantage998
  • 143 posts
Posted 04 February 2010 - 09:38 AM
If you haven't finalised the damper mounting i would suggest something like used on the gtm:
#239 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 04 February 2010 - 09:46 AM
What's that the back of ?
#240 advantage998
advantage998
  • 143 posts
Posted 04 February 2010 - 01:33 PM
My old GTM Rossa.
