1275 Engines, Bhp As Standard
14 replies to this topic
#1 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 09 January 2008 - 11:22 PM
Hello all
Im looking for the following information.
I am looking for the lowest BHP producing 1275 engine that was made and what make/model & level of trim it was fitted too, an approx year would be great.
Jordie
#2 Rhys
Rhys
  • 898 posts
Posted 10 January 2008 - 07:30 AM
im pretty sure it was the late 1275 GT engine's 1974-80 i believe i will get a link for you.
Its about 1/4 of the way down that page
Here
Rhys
Edited by Rhys, 10 January 2008 - 07:32 AM.
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 10 January 2008 - 08:28 AM
Incorrect...
The 'lowest performing' 1275's are the last of the A+ 1275's in basic trim, ie sprites etc....
#4 ForrestGrr
ForrestGrr
  • 25 posts
  • Local Club: Mini Seven Club Nederland
Posted 10 January 2008 - 09:40 AM
Incorrect...
I hope i'm not going too far offtopic with this, but what is the difference between say a A+ 1275cc Mayfair and a A+ 1275cc Cooper of the same year? To start with the camshaft i suppose, anything else?
#5 collmotorserv
collmotorserv
    Starting My Mini Up
  • 1 posts
  • Local Club: bmoc
Posted 10 January 2008 - 09:53 AM
hi lowest bhp 1275 53 bhp fitted to mini between 1991-1996 engine no 12A2DF75/6
THANKS FROM CMS www.mini-specialsit.co.uk
#6 sheree&the-gt
sheree&the-gt
  • 909 posts
  • Local Club: Leeds MOC
Posted 10 January 2008 - 10:21 AM
is there anywhere where you can obtain rough estimates for bhp for normal engine setup & ones with stage kits on?
just need some rough guide for ideas thats all :w00t:
sorry to go OT
X
#7 998dave
998dave
    998cc's Of Dave Goodness
  • 4,566 posts
  • Name: Dave
Posted 10 January 2008 - 12:28 PM
sorry to go OT
X
Yes there is - Download WinSU, (find it on Google), and enter your spec, it'll give you rough power and torque curves, if you buy the software for £9.99 (I think), then you also get needle recommendations working...
Glad to help,
Dave
#8 alexcrosse
alexcrosse
  • 3,786 posts
Posted 10 January 2008 - 12:36 PM
remember they will loose alot of power over the years. Expect 45-50bhp max from a sprite now adays. Like the engine sat in the corner of my garage
#9 minimender
minimender
  • 1,589 posts
  • Local Club: M.M.M.
Posted 10 January 2008 - 01:12 PM
Well maintained engines don't loose power with age, it's a myth.
Worn out engines loose power. >_<
#10 Aria Aradhea
Aria Aradhea
  • 563 posts
  • Local Club: Jakarta Morris Club
Posted 10 January 2008 - 01:18 PM
Incorrect...
AFAIK, the difference between the two, say a 1994 Mayfair and Cooper SPi is in the camshaft and the compression ratio. The UK market Cooper has the high CR of 10:1 while the export market has the same engine as the Mayfair (low compression 9.4:1), hence the lower bhp...
#11 alexcrosse
alexcrosse
  • 3,786 posts
Posted 10 January 2008 - 05:09 PM
it will looser power, you cannot help certain wear, especially effecting valve lift etc. Carbon deposits etc. Also, if you were to buy a new sprite in 1992 and put it on a rolling road im pretty sure it wouldnt meet the actual power they specified it as.
#12 minimender
minimender
  • 1,589 posts
Posted 10 January 2008 - 05:35 PM
An engine that is well run in and loose will perform better than anew one and continue to perform as long as it is maintained propperly.
There are adjustments thet can be made to allow for wear e.g. tappet clearences, points, carb ajustments, timing adjustments etc.
Plus renewables like plugs, timing chains, clutches, pistons and rings etc ...
So the car should always perform at least as good as new, if not better >_<
Edited by minimender, 10 January 2008 - 05:35 PM.
#13 ForrestGrr
ForrestGrr
  • 25 posts
Posted 10 January 2008 - 06:04 PM
Ahh ok, thanks for the awnser! So how do increase the compression ratio, do the coopers have different pistons or is it gasket related?
(I have a cooper with a mayfair engine >_< )
#14 alexcrosse
alexcrosse
  • 3,786 posts
Posted 10 January 2008 - 06:07 PM
well when the cams wear there is no way that you can get the same lift without a modified rocker ratio... which isnt a standard engine any more. And cams do wear, fact. And if you on about changing pistons... your doing a complete engine rebuild, lmao, ofcourse ill be the same after that, its a complete engine rebuild, but ur spending alot of money.
#15 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 10 January 2008 - 06:11 PM
cheers people
I passed on this information to my friend who was asking
