Posted 09 January 2008 - 05:20 PM
Some may tell you that a Sports Coil or other performance coil is great. I will not.
The premise that one coil is better than another often hinges around discussing the output voltage of the coil. This can range from 20kV to perhaps 40kV for "standard" coils. Some coils for later cars than the Mini may be classified as HEI ignition coils and these go significantly higher. The problem with changing the coil alone is that the coil doesn't create a hotter spark or one that lasts longer. To get a hotter longer firing spark requires changes to the distributor and opening up the spark plug gap.
The voltage of of a spark at the plugs is controlled not by the coil but by the plug gap. The wider the gap, the higher the voltage to jump across the gap. In theory, this makes a hotter spark. However, the length of time the coil has to charge and discharge to deliver this hotter spark is controlled by the dwell time of the distributor. Electronic ignitions (in general) allow the coil to achieve these hotter sparks.
In summary, if all you're changing is the coil, you won't see any improvement worth mentioning. If you have electronic ignition, you may find you can open the plug gap up a bit. I think you'd still need to experiment with the settings to find what works best for your engine. If you stick with the stock settings though, the coil alone won't make any difference in performance or economy.
