When removing one from mine I tightened the flywheel, then with the starter motor out hit the rear of the flywheel with a drift a few times, turned a bit, and repeated, tightening the puller when possible, eventually came off, but was hard work!
is the best way to cause this:
Flywheels get hairline cracks very easily and if yours gets one it will shatter at road speeds, this essentially means a fairly large explosion in the engine bay.
No it's not just a myth or scaremongering, quite a few of our members have had this happen to them after smacking their flywheels.
If you are going to lap your crank, don't do it very much. All you do when lapping a taper is chase the taper further up the shaft it is on. If the flywheel moves much further up the shaft than it already is it gets too close to the oil seal and the back of the transfer chest and too far from the clutch release. It will make the flywheel fit better but be careful. As for making it just fall off later, the better the taper fits the more it will lock up! It's the taper that holds the flywheel on, not the bolt.
Edited by Dan, 08 January 2008 - 01:07 PM.
