Shot Blasting Or Chemical Dipping?
Posted 02 January 2008 - 05:44 PM
I was thinking about getting my z cars shell shot lasted or even chemically stripped and primed but the cost of the strip am priming is very very high and tey recon that the shell cant be taken in till mid july.
here is the break down of chemically stripping the shell. The shell has been stripped by wire brush already but does have lots of surface rust on ut now!
COST OF DIPPING AND STRIPPING £595 plus vat
COST OF HAVING IT E COATED £795 plus vat
What do ytou all think?Do you feel that shot blasting and priming would be much better and cheeper??
Phil
Posted 02 January 2008 - 05:56 PM
Not had it done, but it is generally deemed to be a lot kinder to the shell..
I got a quote of 250 to blast my van.
Posted 02 January 2008 - 06:01 PM
if you ever see it on tv watch camper van crisis on discovery channel and see how much dipping removes
Posted 02 January 2008 - 06:07 PM
the advantage of the dipping is it gets to all the inside of the box sections unlike blasting
Surely if you have it dipped and it cleans inside all of the box sections etc You would have to have it E coated or dipped in some sort of primer otherwise the insde of the box section would be bare metal and rust rather fast!
Posted 02 January 2008 - 06:18 PM
Hi all
Phil
Do you mean Zcars or Zeemax shell? if you did mean Zcars does that mean your putting a Zcars engine in a Zeemax mini?
Do you have to take the Zeemax kit off to get it shot blasted? If not it would ruin the kit wouldnt it?
Posted 02 January 2008 - 06:19 PM
Surely there is only the inner sills which would require cleaning on the shell as there would be very l;ittle to it, being a z car shell. no back end or front with it being fibre glass??
Phil
Posted 02 January 2008 - 06:21 PM
Phil
Posted 02 January 2008 - 07:10 PM
yep thats the idea
