Vin Plate Location
27 replies to this topic
#16 jayare
jayare
  • 2,093 posts
Posted 29 December 2007 - 11:31 PM
Those are codes for earlier chassis numbers - for example XC2W2xxxxxx is a 1098cc Clubman Estate number xxxxxx. Not sure if the later VIN numbers use the same coding but there will be a specific code for them as well.
JR
#17 jack_marshall
jack_marshall
  • 2,540 posts
Posted 29 December 2007 - 11:32 PM
Ive noticed on a late cooper we have at work, the vin is riveted to the boot floor.
This maybe cause its a japanese import though, and with the extra air con under the bonnet, theres no room for the vin to be seen under there.
#18 herpsuk
herpsuk
  • 80 posts
  • Local Club: NWMC
Posted 31 December 2007 - 12:07 PM
Well there is a plate located on the very front wing on the inside of the engine bay on the drivers side, its a 17characterlong number as well. am i right in syaing this will be it?
thanks
J
Edited by herpsuk, 31 December 2007 - 12:11 PM.
#19 jayare
jayare
  • 2,093 posts
Posted 31 December 2007 - 01:42 PM
Yes - that's the one - the VIN number will start SAXX.... IIRC.
Paint & trim codes are at the top of the plate as well on these types.
JR
Edit: The VIN number should also be stamped in the scuttle panel rain channel at the back of the engine bay on this sort of age Mini.
Edited by jayare, 31 December 2007 - 01:43 PM.
#20 minimender
minimender
  • 1,589 posts
  • Local Club: M.M.M.
Posted 31 December 2007 - 03:40 PM
Have a look at 'what mk is my mini' thread, for vin plates + location
#21 herpsuk
herpsuk
  • 80 posts
  • Local Club: NWMC
Posted 04 January 2008 - 03:49 PM
For the mnumber on the scuttle where exactly is it located? drivers/passenger side? or in the middle and how far down from the scuttle/up form the bottom of the car
much appreciated
J
#22 minimender
minimender
  • 1,589 posts
Posted 04 January 2008 - 03:54 PM
Found this the other day
Attached File  INFO_MINI.jpg   515.25K   11 downloads
I wnder if it still applies ??
#23 minimender
minimender
  • 1,589 posts
Posted 04 January 2008 - 03:57 PM
much appreciated
J
If you want the one stamped into the body then it should be above the master cylinders in the rain channel just below the windscreen. It's not easy to find , best feel for it
#24 herpsuk
herpsuk
  • 80 posts
  • Local Club: NWMC
Posted 04 January 2008 - 04:44 PM
thanks, ill go ripping out the sound deadening stuff from the engine bay to find it now lol.
wil ahve to do so in morning, its to dark n cold now =]
thanks guys >_<
#25 ian
ian
  • 676 posts
Posted 04 January 2008 - 04:59 PM
No its not behind the sound deadening, open the bonnet and you will have like a u shape on the edge of the scuttle, its a rain channel, the number will be stamped in the bottom of the u shape.
very hard to explain lol
#26 Ingloriousmint
Ingloriousmint
    Starting My Mini Up
  • 1 posts
Posted 08 December 2011 - 08:49 PM
What if your scuttle panel has been replaced due to rust?
#27 MiniManiac
MiniManiac
  • 39 posts
Posted 12 April 2012 - 06:55 PM
First of all, I apologise for piggy backing on this thread, but I have a similar/related issue. Thank you so much for taking the time to help me out if you can
I am looking to buy a Mini pickup which the owner says and it is registered in Costa Rica as a 1975 (not much of a difference here, it could be any year).
I went to look for any identifying numbers and found the following series:
U/014xxxL Under the front lip of the bonnet, where it latches the body.
FE1979xx5 On the right side of the chassis next to the motor, right under the bonnet.
85HxxxPxxx19 on the engine (Someone on a different thread already shed some light to it being an 850cc and not a 1100cc as the Costarican registry shows)
I am suspicious of all three series since my search on the internet has turned nothing similar for any pickups '75 or otherwise. i suspect the engine is not an original pickup but belonged to some other Mini and was put in the pickup. As for the other numbers, I know U is for pickup, but as I understand it there should be several more letters on that series. and as for the FE, so far no search has come back with anything similar.
Does anyone at all have any idea if this is a legitimate '75 pickup, maybe not built in the UK or what these numbers mean or where they are from??
#28 mab01uk
mab01uk
  • 12,412 posts
Posted 12 April 2012 - 11:04 PM
The FE number is the Front Assembly number and has little bearing on the date of manufacture of the car.
The FE number is a number originally used in the factory and doesn't seem to mean much in the outside world, FE = Front End I think.
The FE number was usually reversed stamped into a welded plate.
VIN Numbers:
http://www.minimania...atagory=General
Edited by mab01uk, 12 April 2012 - 11:05 PM.
