Vin Plate Location
Posted 29 December 2007 - 10:15 PM
I want to check it before i hand over the cash and to write the number down before i actually pay the lad the money for the car.
much apprecoiated
Jonathan
Posted 29 December 2007 - 10:20 PM
its a plate rivited on to make ringing hard
Posted 29 December 2007 - 10:23 PM
The vehicle identity number (VIN) is stamped into the body . It's in the bonnet rain gutter above the brake and clutch resevoir below the windscreen. Move the rubber to see it and you may need a damp cloth to clean the paint.on the slam panel where the bonnet closes
Posted 29 December 2007 - 10:27 PM
Posted 29 December 2007 - 10:30 PM
Does it make it hard to ring a mini?on the slam panel where the bonnet closes
Posted 29 December 2007 - 10:35 PM
[/quote]
Wouldn't dream of it
The ealier cars had the vin stamped in above the boot handle.
Any more places ??
Posted 29 December 2007 - 10:37 PM
I had an 85 with it at the front. Having said that it was reshelled late 80s so maybe your right.its not there on all mini's only after late 80's on wards
Posted 29 December 2007 - 10:38 PM
Posted 29 December 2007 - 10:40 PM
Isnt it on some of them on a plate above rad and inner wing?
yep thats where mine is
Posted 29 December 2007 - 10:42 PM
Think you will find that is the paint codeIsnt it on some of them on a plate above rad and inner wing?
Posted 29 December 2007 - 10:44 PM
i fort the paint code was only 3 letters long this has about 20 or so
Posted 29 December 2007 - 10:47 PM
Posted 29 December 2007 - 10:49 PM
JR
Posted 29 December 2007 - 10:51 PM
[/quote]
You know I think you might have something there.
It is a code including the paint though and not a VIN number. Paint I think is 1 letter 4 numbers. yes it is
May be a trim code then...someone must know
I'll have to check.....
Posted 29 December 2007 - 11:09 PM
The VIN plate tells you,... the EEC type approval number, paint and trim codes, weight and loading codes, and the vehicle identification number.
The plate is fitted to saloons on the left hand front inner wing panel (I was wrong)
On estates the plate is on top of the panel next to rad but flat(suppose that is clubmans as well)
On vans and pickups the plate is on the front of the right hand inner wing panel.
Only late models (eighties I presume) have a paint code.
some of the code means;-
X ....BL internal reference
K...848cc
L...998cc
C...1098cc
2W ...2 door estate
2S...2 door saloon
G...post office van
V...van
U... pick up
1 ...1st series
2...clubman
I dont understand it either
