any help would be good
sorry about the picture but u i thought it might help
cheers
Posted 22 December 2007 - 05:20 PM
Posted 22 December 2007 - 05:30 PM
Posted 22 December 2007 - 05:38 PM
Posted 22 December 2007 - 05:41 PM
is the car taxed and road legal? there's a discussion goin on somewhere else about this. If a weel touches a road then it has to be road legal.
Posted 22 December 2007 - 06:38 PM
Posted 22 December 2007 - 07:29 PM
Yup but because the Mini is too heavy to be an unbraked trailer it would need to be linked to your car's braking system, which it isn't and can't be. That's why towing with an A frame is illegal, just as towing with a rope is illegal. You need a trailer or a tow truck.
Posted 22 December 2007 - 08:07 PM
The reallty of the situation is that 99.99% of the time, NOBODY cares and most EU countries don't really worry about it
Posted 22 December 2007 - 09:49 PM
i asked about this, and i was told it doesnt matter if its being toed, because there is no-one in it driving and it is basically a trailor which is using your car as the brakes!
Posted 22 December 2007 - 10:05 PM
A-frames can really only be used legally for towing cars if
(a) the car is been recovered after a breakdown or
(b) the weight of the towed car and A-frame is below 750kgs
The lights on the rear of the towed vehicle must comply with other regs for trailers, including warning reflective triangles and towing vehicle reg plate.
The C & U (construction and use) regulations treat vehicles connected by a rigid coupling as a towing vehicle and trailer. The use of an A-frame thus means that the towed car becomes the trailer in the eyes of the law, and therefore must comply with the normal requirements of a trailer.
Edited by Jordie, 16 January 2008 - 07:15 PM.
Posted 22 December 2007 - 11:48 PM
Mini Weight (curb) = 617 kg (1,360 lb) to 686 kg
both our A-frames are equal to 25-30kg
That adds upto under 750kg
But thats my input on this. Ive just been talking to the traffic police and FTA today about this. Turns out its perfectly legal for me to tow my mini using an A-frame.
While it is not specifically illegal to tow with a rope (meaning there is no statute specifically referring to it) you can be prosecuted for it.
There are lots of things that are not specifically illegal but are regarded as Driving Without Due Care or simply as Dangerous Driving. Something doesn't have to be specifically written down to be against the law, precedance can make something illegal. People have been and continue to be prosecuted for Dangerous Driving for towing with a rope and that means that you can be too, especially since the Highway Code published that it should be avoided where possible (or something like that). Tow with a rope at your own risk but it is regarded as being an emergency measure to find a place of safety and clear the carriageway now and not for long or intentional journeys. If a Policeman decides that you didn't really need to make the journey using a tow rope and it was dangerous or irresponsible to do so, you can end up in court for doing so.
Posted 23 December 2007 - 12:14 AM
No you can't, it does have to be written down to be against the law!
Posted 23 December 2007 - 01:48 AM
Posted 23 December 2007 - 08:49 AM
Edited by Jordie, 23 December 2007 - 08:53 AM.
Posted 23 December 2007 - 09:37 AM
Find a law that says it's illegal to drive on the right hand side of the carriageway.
In any case we're agreed that it's basically illegal to tow with an A frame now. by the way Jordie, as Sixwheeler says the absolute weight limit for an unbraked trailer is based on the gross trailer weight but also may not be more than half the kerb weight of the towing vehicle. That means that even if you could tow a Mini based on the Mini's kerb weight alone you'd need at least a car with a kerb weight of 1400kg. I used to have the last published gross weight for a Mini somewhere but I can't find it now. Bearing in mind that it's designed to carry three adult passengers in addition to the driver (already included in the kerb weight), extra weight allowance for the driver because the included allowance isn't much (68kg) and some extra luggage you have to think it's around 950kg.
Posted 23 December 2007 - 11:19 AM
