Hi there i have a engine that im storing at the moment which is lying outside of the car.
Should i put a tea spoon of oil down the bores to stop it corroding. Also i took the head off the other day and a little tiny bit off coolant went down the bore but i cleared this out as much as i could.
Will the oil make it rust faster f theres been abit of water down the bore i got alot of the water out and the bore was dry.
Shouldi put the oil down the bores ?
Oil Down The Bores
89mini
, Dec 17 2007 06:04 PM
8 replies to this topic
Posted 17 December 2007 - 06:04 PM
Posted 17 December 2007 - 06:06 PM
Ill be putting the oil trough the spark plug hole if this makes any difference ?
Posted 17 December 2007 - 06:26 PM
Do it just to coat them and keep them clean. Don't forget to do it again when you take the car out of storage along with turning the engine over to get oil pressure up.
How long you sticking the car away for?
Posted 17 December 2007 - 07:21 PM
the engine is out of the car. will the little bit of coolant that went down the bore mess everything up now ? Im really worrying about it ?
I torqued the head right back down so will it rust up ? I cleard the water with loads of tissue paper and turned the engine like a hundred times by hand wiping the water on the sides of the bores until it was dry or at least almost dry.
Posted 17 December 2007 - 07:25 PM
nope, shouldnt be a problem jsut put some oil down the bores and hand turn it over every now and again untill refitted and it should be fine:)
Posted 17 December 2007 - 08:02 PM
i just put some oil down there, turned it over a few times, hopefully all should be well
Posted 17 December 2007 - 11:28 PM
Use a long spouted oil can to get the oil right down where it needs to be. Using a tea spoon would be pointless.
Posted 19 December 2007 - 05:54 PM
taffy has it - you need to use a gun with a squirter/spout to hit the bore wall - you wont get it all anyway...
a teasspoon of oil will sit nicely in the dish on the piston and not hit the wall at all...
Posted 24 December 2007 - 11:51 PM
