Basically i like the sounds of electronic ignition - Better reliability.
My minis been having a few probs with misfiring and the like due to the damp so was thinking about fitting electronic ignition. Firstly can somebody explain what electric ignition does? How much of the distributor does it replace - i.e. points? rotor arm?
Secondly what sort of advantages are there with it over standard ignition - i've researched it abit but most sites have basic info and only seem to mention about much higher voltage spark - but what advantage does this give me in real life terms. Also websites seem to mention an increase in BHP - I assume this is only on high performance engines that were being held back by the standard ignition system?
Finally what sort of kits are availible? I've found the aldon ignitor kits and thats about it - i'd like to know what other options there are. Is there a brand i should stick too. Also Aldon seem to offer the flamethrower coil along side this kit - I've just fitted a brand new sports coil and don't want to replace that so soon - are the electronic ignition kits compatible with sports coils?
Are the gains worth the cash?
