so can someone tell me where abouts the adjustment point is please.
cheers
bb
Posted 30 November 2007 - 01:49 PM
Posted 30 November 2007 - 01:56 PM
Posted 30 November 2007 - 01:57 PM
Posted 30 November 2007 - 02:15 PM
If you mean the throw adjust then it's the big 15/16th bolt at the bottom of the arm.
Posted 30 November 2007 - 02:17 PM
First, what type of clutch do you have...
If it's a verto (clutch slave on plate over clutch cover with short actuating arm ) then it's not adjustable, the only thing you can really do is set the throw out stop and blead the hydraulics.
If it's a diaphram ( clutch slave attached to transfer case and long arm ) then there is some clutch attached adjustments associated with the arm return bolt and the throwout, and then there's also the actual flywheel/clutch setup which is adjustable ( or rather it'c setting it up correctly )
Posted 30 November 2007 - 02:25 PM
Posted 30 November 2007 - 04:39 PM
the clutch plunger....
