Ex-Rally Car
776 replies to this topic
#121 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,139 posts
  • Name: Sean
Posted 15 April 2009 - 11:28 PM
Looking good, have you got that wiring module yet?
Just a thought but it may be worth mounting it on rubber feet(I've seen your driving!!)
So when's it gonna be ready for then?
#122 mini93
mini93
    He's just too casual!
  • 8,615 posts
Posted 15 April 2009 - 11:34 PM
ordered it last night, got an email at 9am this morning...its on its way :)
ill put rubber under it but thinking it will be mounted on fibreglass...should be alright...and you havent seen my driving :P i havent been in my mini at a show recently haha
hmm...thinking i should be able to get it done for next weekend, i hope!!
fancy coming to help wire up? :withstupid: haha
#123 Shifty
Shifty
  • 13,139 posts
  • Name: Sean
Posted 15 April 2009 - 11:36 PM
You should be ok.
From the look of the diagram its childs play!!
Basically you just connect the headlamps/indicators/etc straight to the new fuse board.
(what could go wrong!!!)
#124 mini93
mini93
  • 8,615 posts
Posted 15 April 2009 - 11:40 PM
hmm i dunno, stil few things im iffy about on that wiring diagram.
need to also work out a way to get a take off from my inlet manifold, need 2 pipes then a pipe going to the megajolt. need screw in union type nipplily things but not sure really...but confused as to how to go about it
#125 Shifty
Shifty
  • 13,139 posts
  • Name: Sean
Posted 15 April 2009 - 11:44 PM
Have you seen the one that "The Matt" did?
He used industrial pneumatic tube fittings, dead easy, just need a 1/4bsp tap a few fittings and job done(I have all those if you need em!!)
Although really those type of fittings need positive pressure to work they are ok with vacuum. Another way would be to use hose tail or barb type fittings.
The tube is available in lots of different colours as well!!
#126 mini93
mini93
  • 8,615 posts
Posted 15 April 2009 - 11:50 PM
yeah, i saw what he had but dont even know where id get that stuff localy, im not sure if its negative or positive pressure because its after the buterfly, surly must be same kinda thing as vacume gauge, i think thats negative, obviously trying to get air from where ever it can, more so with throttle closed.
saw something on demon tweeks which would work...but my my that was expensive £18 each n i would need 2
#127 Shifty
Shifty
  • 13,139 posts
  • Name: Sean
Posted 15 April 2009 - 11:55 PM
I can get you what you need for the price of postage and a beer at the next show!!
Pneumatic fittings are something I have in abundance!!
I use them everyday at work and have loads of them!
All I need to know is the size of the pipe inlet into the megajolt and I can work it back from there.
#128 mini93
mini93
  • 8,615 posts
Posted 16 April 2009 - 12:00 AM
the MJ will need an internal diameter of 3mm :)| its 3mm with a single barb of 5mm across ( the measurments are across a rule not circomfrance)
not sure if will be best to have a wider one on the manifold and use reducers?
#129 Shifty
Shifty
  • 13,139 posts
  • Name: Sean
Posted 16 April 2009 - 12:06 AM
Sounds like 6mm od tube with an Id of 4mm would be ideal?
Pair of 6mm elbows with T piece and job done.
#130 mini93
mini93
  • 8,615 posts
Posted 16 April 2009 - 12:10 AM
so the 6mm t-piece...would this increase the ID of tubes going to the manifold?
i found a place on internet local to me who deal in pnumatic stuff, send me a PM with you mobile number, if im unsuccessful with this place tomorrow morning would i be able to ask help with seeking suitable parts from yourself?
#131 Shifty
Shifty
  • 13,139 posts
  • Name: Sean
Posted 16 April 2009 - 12:17 AM
No, to be honest I wouldn't bother, the more joints you have the more complicated it becomes and the more chance of leaks.
6mm tube will flow a considerable amount of air,
The important bit is getting the tubes the same length, otherwise you'll get an imabalance.
The bits are easy enough to source.
You'll need
2m 6mm polyurethene tube
2x 6mm - 1/4bsp elbows
6mm push fit equal T piece.
A 1/4 BSP tap, I bet Southam will have one.
Use a sharp stanley knife blade or even better a proper pneumatic tube cutter to cut the pipe(cheap enough)
Don't use side cutters!!
I'll drop you a PM with my no
#132 mini93
mini93
  • 8,615 posts
Posted 16 April 2009 - 12:22 AM
so i ask for the OD of the tube then? (being 6mm) i got confused, thought you meant the ID increased to 6mm
#133 Shifty
Shifty
  • 13,139 posts
  • Name: Sean
Posted 16 April 2009 - 12:25 AM
Take the jolt unit with you and you can check it for fit on the tube.
Yup, you ask for the tube based on the OD.
#134 mini93
mini93
  • 8,615 posts
Posted 16 April 2009 - 12:27 AM
yep, was planning to take jolt and fanimold to the place n see what they say....ill let you know! :)
thanks for you help!!
Edited by mini93, 16 April 2009 - 12:27 AM.
#135 Shifty
Shifty
  • 13,139 posts
  • Name: Sean
Posted 16 April 2009 - 12:30 AM
No problems dude!!!
