Ex-Rally Car
#436
Posted 19 June 2012 - 09:35 PM
#437
Posted 19 June 2012 - 09:42 PM
#438
Posted 29 June 2012 - 10:26 PM
My toolbox arrived, makes working on the car... no different really
Iv cut the inside roof rails down to the top swage. going to leave it at that, just tidy up the extra burrs. Need to leave a little strength there.
Iv also cut the rails on that are round the front and rear screen completly out. Makes things a little floppy at the roof line, but theres a few bits n bobs that need to go back in later on. a few small gussets to the cage, nothing extreme, just a few tags
The top dash rail will come out soon. (actualy thought it was finally finally blast ready till i remembered just this minute i hadnt done this!) anyway, dash will be held in with a few small tags welded onto the bulkhead with riv-nuts in,
also old heater brackets will go, going to use a light weight heater or electric screen.
Iv had fun with an annoying neighbour too. 2 days in a row shes come over complaining about noise. 1st day. thursday. I stopped as it was 8pm and getting late, admittedly
today, friday, at 6:30 she comes over, hostile and threatening me with official complains saying i should be renting a unit to work on a car making all these noises. I dont have the money to pay for it, so i told her i wasnt going to stop but that we needed to come to an arrangment, to which she replied "yeah, your going to stop" pfft!! balls to THAT!
#439
Posted 15 July 2012 - 05:55 PM
I'm bored of cutting it up!
It need blasting so i can start adding metal and making myself feel better about it.
Chopped the top rail out arround the windscreen
also chopped out the top dash rail
Altho, theres still a little more to chop out
Ill be phoning the blaster guy in the week to arrange it i guess!
#440
Posted 15 July 2012 - 06:44 PM
#441
Posted 15 July 2012 - 07:09 PM
The cage is in the way in alot of places.
for example cutting out the boot floor was fine n dandy cutting out, plenty of space to chop chop without getting a face full of sparks. Cutting out my top dash rail was nasty. I chopped most of the rail out using a 1mm disk, and then used a chissle to pull the remaining metal and to find the spot welds, which i then ground down and removed. however the end of the rails are behind my cages A-supports so bit of a ball ache to get into.
I also removed the heater brackets, nice bit of cherry red metal jumped off the bit i was cutting straight onto my thigh... in my work trousers... that are less than a month old
#442
Posted 15 July 2012 - 07:15 PM
will look good blasted, makes it so nice to work with
#443
Posted 15 July 2012 - 07:29 PM
Need to make an ordered list of what to do when it comes back. welding in wise...
Iv still a bit more grinding to do on the underside where iv chopped the valance off too, just the joining flange remains or bits of it at least, it was too high up when it was on its nose so really could do with getting it on the side so its at a good height.
Will get some decent turrets in there too, so might buy them soon to cheer myself up
#444
Posted 17 July 2012 - 08:08 PM
Ill then get it powder coated at a later date along with some other bits and bobs...probably quite a few things actualy. suspension arms, brackets etc
also thinking of sending my wheels inners in for blasting. They're painted bright green at the mo, but id feel better if they were blasted 1st off then powder coated nice bright green.
#445
Posted 18 July 2012 - 09:06 AM
#446
Posted 18 July 2012 - 05:29 PM
Blasting will be next week, i phoned the guy today! woop woop
Edited by mini93, 18 July 2012 - 05:29 PM.
#447
Posted 01 August 2012 - 10:20 PM
Sent away the subframe and the splits inners aswell so they should be nice and spankingly clean soon!
Kinda looking a little lost on the back of a truck!
Also ordered some rear turrets to go in the back.
So looks like it will be next weekend or so by time it comes back from blasting. also hopefully borrowing a friends propper industrial Mig so i wont have to keep faffing around with a shockingly bad hobby welder... then its full blast!
#448
Posted 06 August 2012 - 07:53 PM
Going to have to do it in stages anyway because the amount of junk in the way
already made it brighter in there and thats just the 1 coat and the walls arent done yet.
#449
Posted 06 August 2012 - 08:16 PM
#450
Posted 06 August 2012 - 08:29 PM
Friends had his shell done by the same guy and apparently using softer grit for mine so im sure it will be fine and dandy.
