Ex-Rally Car
776 replies to this topic
#241 mini93
mini93
    He's just too casual!
  • 8,615 posts
Posted 23 August 2010 - 12:01 PM
been over to southam today.
they luckily said that see no problem that the crank should go again aswell as the flywheel. Will need a new ring gear as i said but thats cool because i wanted one :P
then ill take off the high points on the crank and lap the flywheel on and all should be peachy. The reason that its fretted is apparently the torque value quoted in the haynes isnt high enough :)| apparently 170 is the value to aim for...tad confused but hey.
anyway i was like...err i want more power, bigger valves please and he was like hmm well you could do with re-shaping the chambers aswell, if you pop back wednesday ill have a quote for you...at that point i knew my wallet was getting lighter :genius: hope its not more than i can afford because i re-heeeearly want more power. Rod suggested i didnt go above a 300 degree cam due to the final drive, which is already a 3.7 but will see...will do some research, when im driving im not usualy in alot of traffic and its only pulling away till in on power band i have to worry about it and the megajolt should settle things a tad more than a dizzy
#242 AndrewJ530
AndrewJ530
  • 1,628 posts
Posted 23 August 2010 - 04:02 PM
But if you're going turbo in the next year why not save the money off a new 300 cam and put it in the turbo fund :genius:.
#243 alexcrosse
alexcrosse
  • 3,786 posts
Posted 23 August 2010 - 04:06 PM
becauses hes competitive and needs to beat an unnamed mini owner who no longer frequents this forum N/A before moving onto turbos!
#244 mini93
mini93
  • 8,615 posts
Posted 23 August 2010 - 06:54 PM
:) yeah pretty much
and im still very much indecisive who knows if i go turbo or not in the end...urgh how ill miss the webber sound lol
#245 mini93
mini93
  • 8,615 posts
Posted 23 August 2010 - 07:28 PM
its always nice to take off your shock mount and find solid metal...it of course has been strengthened previously anyway but still :)
came off no problem...made me smile
didnt come off so free :) snapped every single bloody bolt....urgh, lucky that you can get nuts behind so im going to throw a drill through the holes and either tap them out or sneek up nuts behind and bolt through that way.
inner arch cleaned up quite nice too also
#246 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 23 August 2010 - 07:52 PM
Oh shock absorber mounts! all ways fun fun fun! at least dot have to worry about the front end getting in the way!
#247 mini93
mini93
  • 8,615 posts
Posted 23 August 2010 - 07:56 PM
its not so bad :) used to drill out at least 1 bolt a day when i was working with turbos, the heat cycles they go through mean they just snap when you come to take them apart...only difference is my drill and bits at home arent as good as when i was working :) might have to invest lol
#248 mini93
mini93
  • 8,615 posts
Posted 24 August 2010 - 05:10 PM
must remember...less haste :huh:
spent the afternoon de-greasing the subframe and bulkhead then thought id just chop the inner wings a tad more.
they now look like
problem is that i attached the plates for the bonnet pins to the scuttle and inner wings. I also need to make a bracket to support the wings, will help them fit better i hope...so will just be a more complecated bracket now :wub:
glad i was wearing my overalls today! the wire wheel attachment which has previously tore into my hand tried to bite me again today, snatched the bulkhead and flicked towards my leg, luckily it wrapped up in the overalls before it bit tore into my leg
#249 mini93
mini93
  • 8,615 posts
Posted 25 August 2010 - 10:11 AM
can anyone guess why iv bought this?
who can tell me what its for?
#250 GraemeC
GraemeC
  • 7,472 posts
Posted 25 August 2010 - 11:07 AM
UJ usually used for internal gear linkage.
Could also be used in steering column.
#251 mini93
mini93
  • 8,615 posts
Posted 25 August 2010 - 12:24 PM
ah that didnt last long :D thought some clueless might just come along with some funny guesses.
certainly not large enough for the steering column though
its a tiny bit too small but thats alright, its 1/2 inch ID so will need a slight file on the shaft but should be a big deal.
plans later are custom exhaust so with it being internal ill be able to get the exhaust made to sit reet up high.
Edit: actualy know what...put my clever head on, completly daft of me to spend money on the head when in the future im going to want to go even bigger inevetably and till im earning i wont be able to do that.
So for now its going to stay "slow" It would be stupid for me to spend money right away when it still drives alright and well. When im earning moneys ill decide the propper route ill take, but i know for sure its not going to be cheap haha.
If i was going to spend money right now, it would be going on some suspension parts
still getting my flywheel sorted as i quite fancy the reliability haha
Edited by mini93, 25 August 2010 - 02:21 PM.
#252 danny1
danny1
    In the navy you can sail 7 peas
  • 1,321 posts
  • Local Club: bumpstart
Posted 25 August 2010 - 08:52 PM
can i ask were you got the uj from?
#253 mini93
mini93
  • 8,615 posts
Posted 25 August 2010 - 09:37 PM
yes, you can....eeeebaaay! was actualy listed from demontweeks, listed as a racetech/mollart UJ...however on demon tweeks website racetech Uj's are up around the £50 mark :D i got it for £25 including postage which was useful as iv been looked for a decent priced one for ages.
#254 mini93
mini93
  • 8,615 posts
Posted 27 August 2010 - 08:29 PM
sun managed to break through today, ace!
so managed to get a bit done
this is what my inner wings look like now
then i put seam sealer along the bulkhead line, blend it in a tad better then...
all primed up, looks alot better in one colour i think
all painted in gloss black...showing all the little faults
from the other side, inner wheel arches painted up, again one colour much better i think :D
i spent ages cleaning the transmission housing, taking off flakes of paint n all, also cleaning the clutch housing.
then cleaned the engine, de-greased it all and gave it a coat in black paint, was much better than the gashtacular red/grey/rust/brown/oil...didnt get a pic of it today, maybe when its all back together or something :dozing:
#255 mini93
mini93
  • 8,615 posts
Posted 30 August 2010 - 10:58 PM
3 days and already page 2? its like people do stuff on bank holidays!
just one or 2 useful pics right now but shows most of what iv done
on saturday i cant really remember fully what i did :P but i know i painted the subframe, nice and one colour black now, neater again which i like.
also painted some brackets...all gone black, starting to think theres going to be too much black haha.
re-routed my brake lines, my N/S braded line needs to be cut down...because 1. its too long and 2. i cocked up.... i had my earth clamp of the welder on the suspension and didnt realise the over brade was resting against the earth, so the internal nylon tube melted itself...the brade does a very good job of keeping fluid in...untill you re-assemble your pedal box and press the brake...when it squirts out where ever it fancys :gimme:
lucky enough new olives for the fittings arent too expensive at all and with the material im cutting it down by i have more than enough excess braded line to fix my ******* up...yay
as you can see anyway its all going back together now, running out of things to do so tomorrow i guess ill start putting the engine back together
