breather system
Posted 07 March 2005 - 01:32 AM
i have got all the basics put some of it just isnt clear. as my mini has been in bits for so long now, it is all a little hazy. if anyone acan help that would be great.
cheers
Posted 07 March 2005 - 08:31 AM
998's there's normally just the one on the tappet cover, and sometime on the timing cover, technicaly the oil cap is also a breather. On 1300's there could be one on the flywheel housing, and the timing cover. Essentiall if there is only one, then it is piped directly into the carb, two are usually connected with a "Y" piece and into the carb. You can vent to atmosphere, but put one of those little K&N type filters on the end...
The alternative is to build a bespoke breather system ( including the rocker cover ) and vent to an external collector tank ( ala racing vehicles )
Posted 07 March 2005 - 11:58 PM
Car's all used to vent to atmosphere, but this was outlawed on new cars as it's emissions, However you can modify the vehicle ignoring this regulation and breath to atmosphere.
The normal breather is on the right hand cam-follower cover going up that side of the engine through a filter element, and into the carb inlet.
I'm planning on building a 1275 with two blank cam-follower covers, and instead put a breather pipe and filter to atmosphere of the clutch housing end of the engine to simplify the bay and alloy easier fitment of an Ultimate Head Steady,
Dave
Posted 10 March 2005 - 10:12 AM
im going to build my own system with a catch tank.
Posted 10 March 2005 - 11:04 AM
Just put a tube upwards above the head gasket level and fit a small filter at the top to breath to atmosphere. Oil residue will cool enough and go back down the pipe, or get caught int he filter. And a small amount may dissapear, but will vent out nicely, rather then collecting and going mingy...
This type of pipe is what u want to make.....
Note pic on ebay, so may dissapear within a week or two.
Dave
Posted 10 March 2005 - 11:41 AM
Posted 10 March 2005 - 11:53 AM
Posted 10 March 2005 - 12:24 PM
Posted 10 March 2005 - 12:26 PM
Posted 10 March 2005 - 12:28 PM
Posted 10 March 2005 - 01:55 PM
Contrary to what everyone gets told the combustion chamber isn't sealed, infact you get what's known as blow-by when combustion gases escape past the piston down the cylinder, into the crank case.
This is 10-20 litres per minute... seems a lot? at 4000rpm your 998 mini will transfer 40000 litres. 20 isn't a lot...
Now this gets in the crankcase and pressurises i, which isn't good, so we have a breather normally into the vacuum of the inlet manifold through a PCV (positive crankcase ventillation) valve (effectively a one way valve).
Now instead of doing that we can breathe to ambient, which is also lower pressure then the crankcase.
Dave
Posted 10 March 2005 - 05:22 PM
cheers mates
Posted 10 March 2005 - 07:59 PM
PCV valves haven't been in use on Mini's for decades.
The oil filler cap is also part of the breathing system, as that's where the fresh air comes into the engine from. That's why you have to change it as part of the service schedule.
Posted 10 March 2005 - 09:09 PM
Posted 10 March 2005 - 09:29 PM
