Your rad is pretty much the same size as mine so the 12" will be fine for it as thats what I got, if you want to see the difference in size check out page 10 on mine, posts 137 and 144
Using that DIS will free up a bit more room now, but you might need to change your HT leads if they are the normal honda ones as you need some with the clips on the ends to hold it in place on the coil pack, mine kept coming off at around 90
If you got some magnecor ones on already you can send them back and they change the ends for you for around 20 notes, you need the ford 1st generation ones like this CLICKY or you can buy some leads like I did from CLICK ME just tell the guy you got a honda engine in a mini with a ford mondeo coil pack and he'll know exactly what your on about as he's done a few now, can't remember how much they were??? maybe around 40 or 50 notes?? well worth it though mate
