These were bought from a company called minitastic
Linky Give them a call or drop by and the guy there will help you decide what you need.
Well today was busy. Got the fronts done after alot of shouting as things were so rusted together that they were braking or just not coming off. But with alot of penetrating
spary I got to this
After getting both doughnuts out I was able to check and see if I was right, that it was these causing the car to sit low on the passenger side.
So with these on it should all be good. Had to get my old friend the grider out to cut off one of the old trumpets as I could not for the life of me free the knuckle to use again. Note to self - get a blow torch.
but I was confident so went ahead and did a rear one. Wanted to do them both but time was running out in the day and dam I needed a bath cause I was covered in crud.
The only thing I can say is I'm not too sure how the adjustment is gonna go. I found that to keep the units in position when the car is jacked up the adjusters have to be wound quite far out. This means the car sits high. If I lower it they fall about in the subframes?!? Anyone shead some light on this? I'll see what happens tomorrow when I try some adjustment.
