Great fabrication there on the exhaust, but poor turbo matching and design. Sorry.
If you're overboosting to that degree, your compressor is too big for the engine. The high end of your engine performance should be getting close to the flow capacity of the comp - if not your dragging round extra inertia and will end up with a laggy throttle response as the penalty. No way should you ever need to run a double wastegate arrangement with a single turbo charger thats properly matched.
I know you American guys like to go for the most massive output possible, and tend to end up with these kind of set ups. A properly matched turbo / engine combination will still be quicker on anything other than oval track because it'll spool quicker and accelerate the car while your still winding up your turbine.
I am sure this will be seen as going against the grain of feeling, but just because something might win at top trumps doesn't necessarily mean its going to be the most efficient thought out solution.
I'll add a couple of things. Yes the pre-shot of Nitrous will help greatly. The first manifold that was fabricated was a bad design for the wastegate, we found that out later on. It was a 90 off of the manifold runners. That is a bad design for a turbo like the Borg Warner series that is so efficient it needs to be at a bit of an angle coming off. Coupled with the lack of back pressure due to the short exhaust. This theory can be debated for decades about turbo exhausts and I wont touch it here. The second wastegate in the new configuration really isnt needed but for the bling value you cant beat it and I figured WTH if I do need its there and it doesnt hurt anything if I dont use it. And trust my this turbo is very well matched for this engine.
I would have went inconel but my pocket isnt THAT deep.
Everything I own is for sale except my wife (sometimes she is too haha) and my kid. Its just if the price is right.
Edited by PhotoguyUSA, 27 November 2009 - 07:29 PM.
