Seats That Fit In The Classic Mini
668 replies to this topic
#646 Red Riley
Red Riley
  • 161 posts
  • Local Club: British Car Club of Charleston
Posted 14 December 2020 - 12:27 PM
Mazda Miata (MX5) dyed red to match the rest of the interior.
ACtC-3cuobOj7YBYA1oo_1adseabWDcKTsOBaiAX
What do you have to get the MX5 seats to fit?
Is it a custom subframe?
It is a custom frame, just made by welding some bars front and rear across the Mazda seat slider rails to turn them into a solid base. Then add some rear feet and brackets at the front to mount to the stock seat brackets on the crossmember. They swing up at the front just like the stock seats.
ACtC-3f5cNnhugYIonOuofAehIh42pmeYZ7pATmZ  ACtC-3cFBrRs7kk4TnuWssgu4RWnWnsqiXVkwU_O
Edited by Red Riley, 14 December 2020 - 12:47 PM.
#647 MiNiKiN
MiNiKiN
  • 199 posts
Posted 16 December 2020 - 10:29 AM
Comes with rear passenger shin skinners O_O
Edited by MiNiKiN, 16 December 2020 - 10:29 AM.
#648 riktanius
riktanius
  • 233 posts
Posted 11 March 2021 - 04:27 PM
Thoughts on these Clio seats fitting?
https://www.facebook...place_top_picks
#649 Red Riley
Red Riley
  • 161 posts
Posted 18 March 2021 - 05:53 PM
The only way you could ride in the rear seat is if you didn't have any legs (or shins), so not really a problem.
Edited by Red Riley, 18 March 2021 - 05:54 PM.
#650 MiniCarJack
MiniCarJack
    Formally known as W1NG3D
  • Just Joined
  • 486 posts
  • Local Club: Midweek Minis
Posted 18 March 2021 - 07:41 PM
These seats have already been posted in this thread before, but figured I may as well contribute with photos of my own installation.
Alfa Romeo GTV fronts and matching rear, these were surprisingly easy to fit in the end. I repurposed brackets from a universal aftermarket mini seat subframe, bolted them to some 3mm flat steel, and attached to the factory Alfa runners on the front seats. No welding or custom fabrication needed, and it means the car itself remains totally standard as it picks up off the factory seat brackets, even retaining the anti-tip locking mechanism. The rear seat is just wedged in place at the moment but I'm going to fashion some sort of hook or bracket to prevent the seat back from tipping forward under heavy braking, apart from that they fit like a dream.
#651 mpboullosa
mpboullosa
    Just On Tickover
  • 8 posts
Posted 03 April 2021 - 03:38 AM
Does anybody know the make and model of these seat and if it fits on the mini ?
#652 WindowFinn
WindowFinn
    Just On Tickover
  • 6 posts
Posted 11 April 2021 - 02:44 PM
I have a set of Porsche Boxster seats that I have been trying to fit, but with the runners level with the cross member it feels as if you sit too high - and the seat is on its lowest setting.
With the runners below (and behind) the cross member it fouls the adjuster handle and limits travel in the runners.
The runners have been parallel with the floor through all these tries.
Have others tipped/lowered the runners at the rear or something?
Ta
#653 Quinlan minor
Quinlan minor
  • 1,171 posts
  • Local Club: LSMOC
Posted 11 April 2021 - 03:38 PM
Ta
Takes a bit of work and welding, but this is an option that would resolve your problem.
#654 WindowFinn
WindowFinn
    Just On Tickover
  • 6 posts
Posted 30 April 2021 - 04:15 PM
Ok - Porsche Boxster seats fit, if you tilt them a bit (or maybe I'm just used to the Cobra seats I had).
The backs are nice and high, but still have plenty of clearance for the headlining, the back tilt's forward (with a handle on both sides of the seat) and you can then slide them forward for good access to the rear.
They would tip, but I've nipped the bolts right up.
Still need to wire the back adjustment up.
#655 Verbree
Verbree
    Just On Tickover
  • 5 posts
Posted 10 August 2022 - 07:44 AM
Recently I fitted 2 reclining seats of an Opel Adam in my Classic Mini. Left seat right and right seat left. It takes a little welding using a square bar at the back and 2 supports at the front that fit in the brackets that are attached to the cross member. With a little bit of effort you should be able to pass the luggage compartments that hide the seat belts. The rear seats cannot be used for persons but it already was tight there.
In the UK Opel is Vauxhall.
If it helps I could upload some pictures.
John
Holland
#656 Chris1992
Chris1992
  • 2,022 posts
Posted 11 August 2022 - 09:36 AM
These are my Recaro LX from a Suzuki Ignis Sport. Absolute hell of a job to fit!
#657 rubdub
rubdub
  • 76 posts
Posted 22 June 2023 - 11:52 AM
Looking at putting a set of porshe 944 seats into the mini. I've seen a couple on this thread and it seems they were bolted directly to the floor. Has anyone here been able to use the mounting points on the crossmember as would like to use with my retro components brackets.
#658 Jacko4468
Jacko4468
    Starting My Mini Up
  • 1 posts
Posted 23 June 2023 - 08:32 AM
What about fiat 500 seats looking at
These
Edited by Jacko4468, 23 June 2023 - 08:33 AM.
#659 KTS
KTS
  • 2,421 posts
Posted 23 June 2023 - 09:17 AM
MGF Trophy 160 seats in a pickup
#660 coopertaz
coopertaz
  • 791 posts
  • Local Club: a-series-magpies
Posted 23 June 2023 - 09:38 AM
pretty much fit anything depends on fabrication ability, fitted rover 75 recaros in mine for trip to swiss imm
    Bing (1)
