Anyone fitted Escort RS2000 Recaro Leather seats? If so how do they fit?
Cheers guys, Dan.
Seats That Fit In The Classic Mini
#436
Posted 01 July 2013 - 04:21 PM
#437
Posted 01 July 2013 - 04:41 PM
Mine.
What seat is that? At first thought re fabricated rs seats but not sure? Looks lovely!
#440
Posted 12 July 2013 - 08:09 AM
#441
Posted 12 July 2013 - 02:05 PM
Yes mate and rear seat lol
Ah yeah, haha. Very nice. Was looking at getting a set of these myself
#442
Posted 16 July 2013 - 05:29 AM
Porsche 911 seats - looking a bit tatty, but they will get re-upholstered one day...
They fit very well, although very close on the rear side panel (modified the drivers side on mine a bit) as they are a bit wide.
Super comfortable, I shall be able to travel for several hours without any painnice i have 911 996 Turbo on mine
How did you mount yours on the rear of the stock mounting points? Did you just bolt them to the floor? Isn't the floor metal too thin?
How do you guys mount yours? Mines way too forward using the stock mounting points when using Recaros. But with the Corbeau buckets and stock seats their just fine.
With the Recaros, the rear legs sit somewhere in the middle of the seat, basically supporting all the weight.
The seats were bolted to the floor, using two long U-shaped brackets underneath the runners connected to two 25mm bars running across them. This spreads the weight over the floor and even closed to the edges of the floor.
#443
Posted 16 July 2013 - 02:05 PM
Mounted to the rear of the stock mounting right?
#444
Posted 16 July 2013 - 03:23 PM
hey, iv looked on ebay and found a extended mini seat bracket (http://www.ebay.co.u...=item3f267aa88e) and a pair of seats (http://www.ebay.co.u...=item35c9a1b1de). could u fit these seats to this bracket.
#445
Posted 16 July 2013 - 07:20 PM
If I've understood your question right - no, not mounted to the stock mounting at all. It's two bars mounted to the floor running in parallel to the crossmember. Bolted or welded to those it's a u-shaped bracket underneath the runners. I might be able to find a picture, will try to post it tomorrow.Mounted to the rear of the stock mounting right?
#446
Posted 16 July 2013 - 08:06 PM
#447
Posted 17 July 2013 - 12:26 AM
Pictures would be great.
But I think I got you. Thanks =)
#448
Posted 21 July 2013 - 04:05 AM
This one's the best I've found. I haven't used a full bar underneath the runners by then, later it got replaced by a one piece bar.
#450
Posted 22 July 2013 - 09:46 PM
