I'm picky about the dirver seat position and it needs to push all the way back, but I care less about the passenger so got my drivers seat spot on then put the other one wherever it fit.
Posted 26 February 2013 - 03:17 PM
Posted 26 February 2013 - 03:29 PM
Posted 26 February 2013 - 03:34 PM
Posted 26 February 2013 - 03:52 PM
Posted 26 February 2013 - 04:06 PM
They slide past all pockets front and rear :) I had front pockets in with these seats until i got my new door cards
RS Turbo RECARO's
GOOD TASTE! Exactly the ones I want to refurb
are the rst seats narrow enough to slide past the rear bins?
Posted 27 February 2013 - 05:46 PM
RS Turbo RECARO's
Posted 27 February 2013 - 07:29 PM
Posted 28 February 2013 - 12:39 PM
The door pockets used to touch the sides of the seats, but they slid back and forth really easily. The rear ones don't touch at all.
Posted 28 February 2013 - 10:33 PM
Posted 01 March 2013 - 12:21 PM
Yeah no worries, i made a mock up plan of what i had to do.
RS Turbo RECARO's
I have these & plan to fit them in mine,any chance of a picture of the mounting system you have ?.
The stock subframes are not far from fitting from what i can see on mine as theres a L shape at thefront rails so you can still tilt them.
Any help would be appreciated anyways.
Clifford
IGNORE THE BLUE PIECE DOWN THE MIDDLE AS THIS ISN'T/WASN'T NEEDED.
Black dot's = Bolt's or Welds (your choice) I welded the outer black dots on the red bars and bolts/nuts on the inner ones.
Cheers,
Iain.
Posted 02 March 2013 - 06:27 PM
Mine don't sit high at all and i have done nothing to them, feel's like you're on the floor!
RS Turbo RECARO's
Clifford
Cheers,
Iain.
Using the cobra subframes is an OK solution but they sit reeally quite high for recaro's or at least they did for mine. I had to cut them down quite a lot to get them to an OK height. Id like to make my own tho that fix to the floor to get the ideal high and position.
Posted 03 March 2013 - 04:37 AM
Posted 13 March 2013 - 02:04 PM
Posted 14 March 2013 - 08:23 PM
Posted 16 March 2013 - 09:30 AM
Edited by djfilip1, 16 March 2013 - 09:33 AM.
