Full-size Mini Trailer/double Bed.
#226
Posted 31 July 2008 - 08:43 PM
#227
Posted 31 July 2008 - 10:40 PM
thats bloody cheap!
#228
Posted 31 July 2008 - 10:43 PM
#229
Posted 01 August 2008 - 07:52 AM
did you think of applying a clear polyester scratch resistant seal to the outside face of the acrylic? stops all the scratches
No I hadn't thought of that - thanx for tip.
Got it off fleebay - manufacturer does awesome range all different coloured tints or solids in different sizes, here's a lnk to their shop. Plastic-onlinewhere from?
thats bloody cheap!
Loads 2 do - nottta lottta time left to do them!!!
#230
Posted 02 August 2008 - 08:42 PM
Been cutting out widows on front in "da shack". Out came the sun around 3ish this afternoon, so I fitted 2 rear openers and they look KOOOOOOOOOOL.
Started fitting struts on front of "the tub" to support flipper, dug out chrome bumper, grill, lights, badge etc for fitting soon.
Letz hope weather's better tomorrow.
Edited by dekz2uk, 02 August 2008 - 08:43 PM.
#231
Posted 02 August 2008 - 09:17 PM
#232
Posted 02 August 2008 - 11:09 PM
#233
Posted 03 August 2008 - 10:43 PM
Im now sorted, car purchased. did an oil and filter change today along with a good clean inside and a flushed the system through.
Might change the headgasket to be safe befoer the ring, other than that, its all good.
#234
Posted 05 August 2008 - 06:34 PM
Time for some towbar fitting to "La *******", gotta drop the twin exhaust and drill a few holes in subframe and under back seat. While I'm at it I'm going to check/possibly uprate subframe bolts to be on the safe side.
And then it rained..........................................................................
Ah well, have to go play with MegaSound system and make some cables up.
Soon.
#235
Posted 05 August 2008 - 06:40 PM
#236
Posted 06 August 2008 - 12:39 AM
Keep up the good work
#237
Posted 06 August 2008 - 02:41 AM
#238
Posted 06 August 2008 - 01:31 PM
Onward & upward to the trailer.
#239
Posted 06 August 2008 - 01:38 PM
#240
Posted 06 August 2008 - 03:34 PM
your exhaust doesnt look to happy in that photo
Lookz worse than it is - took it round the farm & down the lane, bumpz, potholez & all. It held up with no nasty noises or anything.
Separated at birth, brought together again by fate (thatz the bo**ocks out the way). Cut & weld time to tow the hitch or is it hitch the tow - whatever!!!
Must crack on only 5 1/2 hours daylight left.
