Racinggreen's 2.1xe
170 replies to this topic
#61 jiminwatford
jiminwatford
  • 310 posts
Posted 27 April 2008 - 07:27 PM
hi mate have you got ya sub frame yet any more progress. have you found a gear box? :)
i've got here if you like. F16 Wide
James, i did think of that, but ive been looking for an f18WR box with a hydro clutch so i could use a willwood pedal box. Do you know if its possible to convert the f16 to a hyro clutch?
i don't, but i'll put a question on the 16vmini forum.
#62 TimS
TimS
    Mini Doctor
  • 2,712 posts
Posted 28 April 2008 - 12:21 AM
It is possible to convert the hydro clutches.
#63 RacingGreen
RacingGreen
  • 2,111 posts
Posted 28 April 2008 - 08:15 AM
Do you know what parts are needed to do it?
#64 RacingGreen
RacingGreen
  • 2,111 posts
Posted 01 May 2008 - 09:32 PM
Really bored, so ive drawn up a to do list. Hopefully i may get some of these crossed off in the next few weeks.
(PART 1)
Collect Subframe and bracebars from allspeed
Fit subframePurchase suspension components, including coilovers.
Source and Purchase engine
Repair corroded hinger panels and fit a panels
Fit flipfront
Fit suspension
Patch front corners of floor
Replace sills
Finish securing rollcage to floor.
Remove remainders of rear valance and boot floor, fit carbon fibre boot floor, new hinge panel and rear valance.
Hopefully il be able to do all the jobs in that order, but we shall see.
#65 RacingGreen
RacingGreen
  • 2,111 posts
Posted 03 May 2008 - 10:21 AM
Went up to allspeed this morning to see rob, it was christmas come early.
Got loads more to buy from him, but im short on cash at the moment. So the other bits will have to wait for now
Fit subframe
Fit flipfront
Fit suspension
Replace sills
#66 RacingGreen
RacingGreen
  • 2,111 posts
Posted 03 May 2008 - 12:32 PM
Old frame removed
#67 shedspeed
shedspeed
  • 38 posts
  • Local Club: rebels mini club
Posted 03 May 2008 - 06:39 PM
looks like you got away to go good luck
#68 RacingGreen
RacingGreen
  • 2,111 posts
Posted 03 May 2008 - 07:05 PM
Thanks. Definately alot to do, but hopefully i should be able to move pretty quickly. Just the cash for parts will hold me back :w00t:
#69 RacingGreen
RacingGreen
  • 2,111 posts
Posted 04 May 2008 - 01:47 PM
Another little bit of progress.
I didnt fit my frame as it kept raining on and off, so i had a go at cutting out my flipfront.:
#70 RacingGreen
RacingGreen
  • 2,111 posts
Posted 10 May 2008 - 11:18 AM
Little more progress over the last few evenings:
Top suspension arms loosely fitted to frame.
Frame fitted
Front end trial fitted on frame
I also replaced the balljoints on one of the hubs and got that painted up, but have no pictures.
Hopefully will get the few bits i need at himley tomorrow. The i should be able to fit the top arms to the frame properly.
#71 The Matt
The Matt
  • 17,231 posts
  • Name: Matt
Posted 13 May 2008 - 07:56 PM
Nice progress Mike!
So, what happens with clearance around the master cylinders? Can you use the normal brake MC? Then convert to cable clutch? Me confuzzled!
#72 RacingGreen
RacingGreen
  • 2,111 posts
Posted 13 May 2008 - 07:59 PM
Il be using a willwood pedal box with the MCs inside the car infront of me. The vauxbox does use a cable clutch but i will be converting it to hydo.
#73 Markld
Markld
    Just On Tickover
  • 6 posts
  • Local Club: 16v Mini Club
Posted 14 May 2008 - 08:47 AM
If you look in my gallery section (MarkLD) on 16vminiclub there is some photos of whats involved with a hydro clutch conversion, very straight forward.
#74 RacingGreen
RacingGreen
  • 2,111 posts
Posted 14 May 2008 - 05:09 PM
thanks mark il take a look.
#75 Pie
Pie
  • 7,695 posts
  • Local Club: GoGoAuto
Posted 14 May 2008 - 05:14 PM
phsss and i was expecting an update lol
