Racinggreen's 2.1xe
170 replies to this topic
#31 RacingGreen
RacingGreen
  • 2,111 posts
Posted 17 December 2007 - 08:05 PM
very nice. Are you going to get him to make up 2 manifolds? may be cheaper and then you can sell the other manifold with the 2carbs u don't use... just a suggestion
I dont think it will be possible to use the other two carbs, as the two end carbs (the ones im planning on using), one has the throttle linkage and the other has the tps on it, so to be able to use the other two, they would need these fitted.
Mike
#32 clubby
clubby
  • 650 posts
  • Local Club: BrEt
Posted 18 December 2007 - 03:15 PM
hye~! mate.. very nice mini
u really deserve to get nice mini due to ur high effort.. good job bro
#33 RacingGreen
RacingGreen
  • 2,111 posts
Posted 24 February 2008 - 11:04 AM
Small update, but not really any progress :thumbsup: but now ive actually got some money together, i can start buying some of the bits i need for the project.
Around a month, and il be back on track :D
#34 lchris21
lchris21
  • 106 posts
Posted 24 February 2008 - 12:21 PM
Nice work, good luck :D
Looking to make a start on my project soon. Engine and front sub out in the same op seems a good idea. Any pitfalls as I'm thinking along the same lines?
Ta
#35 RacingGreen
RacingGreen
  • 2,111 posts
Posted 24 February 2008 - 02:53 PM
Nice work, good luck ;)
Ta
I dont think so, should go fine aslong as you've got enough room to move it all about. Obviously the use of an engine crane was a great help, and a jack to move the engine from under the car.
Also, i suppose you could see, but the weight of the car bent the slam panel (which didnt matter to me).
Mike
#36 RacingGreen
RacingGreen
  • 2,111 posts
Posted 08 March 2008 - 10:01 AM
Right, couple of proper updates (its been a long time since the last)
As can be seen, my cars now in the vauxhall section :unsure:
2nd update is, il be going down to london today to collect a few very nice (big) bits which i thought were bargains, so i can actually get the projet moving again.
I shall have pictures when i return. >_<
Mike
#37 RacingGreen
RacingGreen
  • 2,111 posts
Posted 08 March 2008 - 06:50 PM
Right, after my day out, ive actually got something to show for it:
Safety Devices 6 Point Fia Approved Cage with rollcentre door bars. All for what i thought was a bargain price of £150
Watsons Extended Front Which i paid £100 for :thumbsup:
Tomorrow i might have a go at clearing all the unwanted bits out of the car and fitting the cage in there.
Edited by RacingGreen, 08 March 2008 - 07:01 PM.
#38 jiminwatford
jiminwatford
  • 310 posts
Posted 12 March 2008 - 07:48 PM
Hey mike, why don't you share this over at the 16vmini forum? :D
#39 RacingGreen
RacingGreen
  • 2,111 posts
Posted 13 March 2008 - 06:04 PM
Hey mike, why don't you share this over at the 16vmini forum? >_<
I will be shortly, but theres not much "16valveness" in the project at the moment. so as soon as there is, i definately will be. :-
Edited by RacingGreen, 13 March 2008 - 06:04 PM.
#40 RacingGreen
RacingGreen
  • 2,111 posts
Posted 16 March 2008 - 05:50 PM
Bought a rear valance and the closers from malvern today. When i got back did a little more to the shell, removed both of the doors, got the remaining peice of the O/S wing and got an a panel off.
Should be able to place the order for my subframe on thursday. :)
#41 RacingGreen
RacingGreen
  • 2,111 posts
Posted 19 March 2008 - 06:58 PM
Small update, gave allspeed a call today and ordered my subframe aswell as brace bars for it. So definately no turning back now :thumbsup: Should be able to get it in about 5 weeks. Got a few more bits of the kit i need to order but they can wait untill i have more funds.
#42 *franky*
*franky*
  • 159 posts
Posted 20 March 2008 - 09:07 PM
looks like a cracking project mate keep it up
#43 RacingGreen
RacingGreen
  • 2,111 posts
Posted 22 March 2008 - 10:35 PM
Thanks mate, hopefully things will be moving along a bit quicker soon.
Been thinking about driveshafts today, didnt know if it was wiser to go for the allspeed billet driveshafts aswell as their CV joints, but ive already got a set of calibra ones. hmm, can i afford the price of the billet ones? :lol:
Also, looking for a set of coilovers, so i can get the car on its wheels when the frame is finished. So if anyone has any, they would be much help indeed.
Hopefully get the final bit of the front end removedtomorrow, then i need to start patching the holes i found in the inner wings. When that will be though i dunno.
Mike
Edited by RacingGreen, 22 March 2008 - 10:37 PM.
#44 RacingGreen
RacingGreen
  • 2,111 posts
Posted 23 March 2008 - 03:58 PM
Got a bit done this morning which im pleased about.
Removed other a panel:
Removed all the glass from the car:
Got the other half of the rollcage fitted:
All i need to do to the rollcage now is get some more nuts and bolts and bolt it up tight, then i can make up some spreader plates and fit it to the shell.
#45 RacingGreen
RacingGreen
  • 2,111 posts
Posted 02 April 2008 - 07:11 PM
Another small update i suppose, got the rollcage tightened up and bolted down, and the fits not great, but ok.
Also decided that i will probably tub the rear arches when i do the boot floor, so i can get the car as low as id like to run it.
Still waiting for the call from allspeed. Im not impatient, honestly :thumbsup:
