Wiring Klaxon Horn
24 replies to this topic
#16 Joef
Joef
  • 518 posts
Posted 21 October 2007 - 07:54 AM
You don't need the relay because the cable you are using will easily take the 5A that the horn needs.
the cable might be fine but what about the switch ?
Good point, so the switch needs to be rated at 5A or more as well...
I assumed it would be because usually the smallest you can get is a 5A.
#17 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 21 October 2007 - 07:57 AM
but the horn is a inductive load so you have to derate the switch by 1/2
#18 Joef
Joef
  • 518 posts
Posted 21 October 2007 - 08:09 AM
Well I admit didnt know that.. We use a different type of fuse for an inductive load at work but I've never considered the switch. So you think it needs a minimum of a 6A switch!?
I suppose the relay could be wired next to the switch but then it may as well have been wired in from the start.
Do you know if a brake fluid test switch would take 6A?
Edited by Joef, 21 October 2007 - 08:17 AM.
#19 minili
minili
    Awesome and Flattering
  • 5,140 posts
Posted 21 October 2007 - 04:04 PM
Thanks to everyone who gave me diagrams and help, got it fitted today, and oh so clever as we were it's wired up to the normal horn button and there is a switch on the dash - if it's up you get the normal horn, if it's down you get the special horn :angel:
OOOOOOOOOOOOOOOOOOOOGAH!!!
:wacko:
#20 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 21 October 2007 - 05:36 PM
glad i could be of assistance :wacko:
#21 fireman-sam
fireman-sam
  • 181 posts
  • Local Club: bucks mini club
Posted 06 November 2007 - 12:44 PM
some times i am so clever it hurts :lol:)
others i just fall over that hurts to :-(
glad you like it lisa
#22 BowersMini
BowersMini
  • 102 posts
Posted 06 November 2007 - 04:45 PM
i fitted a dixie horn to my clio! didnt wire it in to my normal horn, just fitted a big red button!
i wanted to put one on my mini, but theres 5 trumpets, 2 of which are rather large
Edited by BowersMini, 06 November 2007 - 04:45 PM.
#23 Retro_10s
Retro_10s
    Moderator
  • 10,138 posts
Posted 06 November 2007 - 04:51 PM
So put it all in your boot.
#24 Mini_Rob_Cov
Mini_Rob_Cov
  • 91 posts
Posted 08 November 2007 - 05:00 PM
I'm putting a dixie in my mini tomorrow (if the weather is alright), plan on putting it inside the right wheel arch just above that big air intake hole. Should be enough room up there
#25 fireman-sam
fireman-sam
  • 181 posts
Posted 09 November 2007 - 10:25 AM
a good place to put air horns when they have 4 or 5 horns is on the rear subframe with all the horns pointing to the back of the car then no rain gets in and you dont feel the pump vib throw the shell
just a thort
and yes lisa it did hust alot lol :shifty:
