Custom Minis R1 Clubman Estate
#136
Posted 03 November 2010 - 07:57 PM
Worrrying on the brakes though, I'm also using .625's .............. time will tell
Not going to see her for 2 weeks now
#137
Posted 04 November 2010 - 08:44 AM
My advice would be to go up to .75's at least for the Wilwoods, unsure about the correct size for the sierra calipers but as they're a single piston I would have thought that .625's would have sufficed. Problem is if your getting a squidgy pedal on one m/c then it'll affect the whole feel of the pedal.
#138
Posted 08 November 2010 - 03:00 PM
Will need to ditch the sierra calipers for racing anyway me thinks so will have to go that route eventually.
#139
Posted 08 November 2010 - 10:06 PM
We're going to give them another go, if it doesn't work I'll get the .725's
Why would they need to be ditched?
David
#140
Posted 09 November 2010 - 09:07 AM
David
Just following suit with Chris really, running wilwood's at the rear.
I'll see how the car performs first before next year but am expecting to have to upgrade.
Les.
#141
Posted 09 November 2010 - 07:47 PM
Les.
I thought Z-Cars ran 2 sets of callipers?!?
The Sierra ones as they have the handbrake feature and the Wilwoods for the improved stopping; they don't or didn't have a handbrake calliper hence the 2 types being fitted.
Happy to stand corrected on this
#142
Posted 10 November 2010 - 05:39 PM
As above happy to stand corrected.
#143
Posted 10 November 2010 - 06:12 PM
zcars use the sierra caliper only for the mechanical handbrake if willwoods are fit too.
if you dont fit willwoods then you have to use the sierra calipers for the footbrake and the handbrake.
i dont think they use sierras calipers anymore has they are getting harder to get hold of, think they now use renault or vw ones
john
I have two sets of calipers on mine but that was at special request as I ordered the race spec version which came with 4x 4pots and the Sierra calipers were needed for a mechanical handbrake, as far as I know two sets is not the norm....
#144
Posted 10 November 2010 - 10:48 PM
If need be I'll remove the mounting tabs for the sierra ones and weld on some lugs to accept the Wilwoods.
hi all,
johnI have two sets of calipers on mine but that was at special request as I ordered the race spec version which came with 4x 4pots and the Sierra calipers were needed for a mechanical handbrake, as far as I know two sets is not the norm....
#145
Posted 10 March 2011 - 10:25 AM
#146
Posted 11 March 2011 - 07:03 PM
Les - any updates? It's been a while so I am expecting some progress...!?!?!
Hi Andy,
Yes, albeit slowly (as usual).
Simple stuff, just the brakes to bleed up.
I believe in making everything simple so I've been using the rivnut tool a lot !! just in terms of access and dismantling. I've re-done a few things to be honest.
Roof is now off but I've been seriously dragging my arse with making the rest of the carbon fibre panels.
Problem I've found is one knock back and I lose interest or if work is busy its put on the back burner.
I have a couple of pictures on facebook and a video from a while back.
Les.
#147
Posted 29 April 2011 - 09:59 AM
Have had to order some more carbon to do the roof, the first attempt was
I bought a Radical rear diffuser off fleabay which after a bit of trimming fits the car really well.
I've been on a few test drives and had an issue with my brakes but all appears to be sorted now
Fire extinguisher needs plumbing in and i need to get the carbon clear coated.
Track day coming very sooonn
#148
Posted 29 April 2011 - 10:10 AM
#149
Posted 29 October 2012 - 10:47 AM
#150
Posted 30 October 2012 - 10:44 PM
Did this ever get finished?
It did, look us up on facebook.com/customminis
Thanks,
Les.
