Ive just dumped my 1380 in after replacing the clutch and top end stuff. I have been cranking it over for a while tryin to start it (got my ht leads all wrong), then just as I get it sounding like its about to fire, the starter motor, although spinning isnt turning the engine over!!
What is the most likely senario? has the it come off the taper? bolt come loose?
it is an pre verto type clutch.
one other thing to add..... when i was bolting the flywheel back together after replacing the clutch, it was really tight to do it up!! although i did torque it up correctly and bend the lockin tap over. did it not go up the taper properly??
any help appreciated!
