Posted 08 October 2007 - 09:56 PM
if you fit 13x7's, you need to trim the OUTER wing, not the inner wing. the wheels are bigger, but its the extra width and offset that causes the problem. last time i done it, i marked from the top of the arch, and in a nice gentle curve, finished about an inch away from the arch lip, at the bumper flange. i then used a large block of wood (i didnt have a proper panel beating dolly) and a hammer to hammer the lip flat. makes it easier to trim. i then marked another line about 10cm (or 3/8ths of an inch) below the original line, and followed it back to the top of the arch. trim along this line. check wheel clearance, if its clear by a centimetre or so you're fine. then when you are done, use a pair of molegrips, or decent pliers, to reform the lip, using the first line as a guide to reform it. I then used a smaller, slightly curved block f wood and a smaller hammer to smoothen up the lip, as using molegrips makes it a bit wobbly. use a grinder to grind back any sharp/rough edges. repaint nicely, then fit arch.
if you do find that the wheels rub on the shocks, (which i doubt they will) use the minimum size of spacer shim and longer studs to suit. a 5mm spacer shim is ok. The wheels may rub on the inner wing on full lock, dont trim these. either fit a lock stop on the steering arm/track rod, or fit a sportspack reduced lock rack.
