Misfire When Hot?
Posted 05 October 2007 - 10:30 AM
1990 City E 998cc. Starts first time, everytime and doesnt skip a beat. HOWEVER, as soon as it gets warm, like ive been rodding around in it for say an hour, constantly, i get a real bad misfire.
NOW...
This has been happening since i changed the plugs, leads and i also did the valve gap clearences. SOme of the gaps were wrong, so i adjusted them, according to Haynes. Do you think this could be the problem??? or shall i start elswhere, like points???
Posted 05 October 2007 - 10:56 AM
CAN YOU LOCATE THE CYLINDER(S) THAT ARE MISFIRING? PRESUMABLY IF IT HAPPENS AT IDLE?I got one for you guys...
NOW...
If so swap the plugs/ leads around (obviously at the plug and the dizzy end) to see if the misfire follows the plug or lead. If so you could have a duff plug or lead.
Did you set the valve clearances with a cold engine?
Posted 05 October 2007 - 10:59 AM
Posted 05 October 2007 - 11:11 AM
Posted 05 October 2007 - 11:13 AM
Posted 05 October 2007 - 04:47 PM
Might try the stuff ive already changed first as it was fine before i changed them. Maybe start with putting the old plugs in and see how i get on
Ill keep you all posted
Posted 06 October 2007 - 09:52 AM
They only cost about £5, mine was £6 and it tests dwell too.
If you're gonna replace parts,.. start with the cheapest first....
Posted 06 October 2007 - 10:31 AM
Posted 03 December 2007 - 08:11 PM
I dont have a condenssor
SO, i managed to matcha new dizzy to the one on my car, but im struggling to find the rota and i thought id replace - is it the igntion module???? Its behing the rota arm and its like a small box, about 2cm x 1cm and has a black and red wire coming out of it. You think this could be it????
Hmmm.....somebody help me
