well a bits cracked off over crimbo n new year,, i have sold my superstars i was fed up with them rubbing on the inner arch and jut generally being hard to steer in comparsion to a 12'' setup. in return for the car i purshaced 2 cobra clubmans with willans 4 point harnesses and a set of 12'' revos..cheers tjenkos!!!
it drives much better now with the smaller wheels i can actually turn the wheel when parking without dislocating my shoulders!!!!!! also with these wheels they are in the confines of the arches so will pass at MOT time, could possibly do with some 1/2 inch spacers to fill them right to the edge but they look good enough for the moment.
i got the seats as the cream ones i have are just not practical for a grubby bugger like myself.. if you were careful with them they would be fine plus they do look ace so these will be for sale soon..
also i got myself a timing light and timed the engine, i cant beleive it was actually starting up because once i got the light on it i found the engine was nearly 90degrees advanced, i guess that explains y it was running a bit rubbish and the mixture had to be so rich also i set the plug gaps as they were around .25mm too wide. on inspection of the plugs cylinder 3&4 were really sooty but cylinders 1&2 were whitey/grey in appearance. does this mean anything to anyone??????
anyhoo i set the timing up at the specified settings and it now runs a dream plus iv been able to weaken the mixture tremendously..
hopefully might get my new doors soon and the removable front end,, just need to work a load of overtime at work because im kinda skint after crimbo..
