Threadlock...
Posted 27 September 2007 - 07:31 PM
Please say no.
Posted 27 September 2007 - 07:32 PM
Posted 27 September 2007 - 07:34 PM
Posted 27 September 2007 - 07:38 PM
Posted 27 September 2007 - 07:39 PM
Posted 27 September 2007 - 07:40 PM
Big end nuts
Haha you're funny. But im funnier. You know why i'm funnier? because i know where you live, ive been round your house. Twice. You have been warned boy.
Posted 27 September 2007 - 07:44 PM
Flanged nuts such as on the big ends preload the threads much like a spring washer would - shouldn't unwind in a hurry.
Posted 27 September 2007 - 08:21 PM
Posted 27 September 2007 - 08:26 PM
as long as they're torqued up they should be fine dude.
Posted 27 September 2007 - 08:58 PM
Just cacking myself a bit as it my first FULL engine build, spending a fair old chunk of cash in the process. Im certain somethings gonna bite me in the ass!
Posted 27 September 2007 - 09:29 PM
JR
Posted 27 September 2007 - 09:41 PM
Posted 27 September 2007 - 09:56 PM
Posted 28 September 2007 - 09:36 AM
Have you used new locktabs or new shouldered bolts or Nylocks in the relevant places? Or new pre-encapsulated bolts (like the oil pump bolts that come with special thread lock on them already?) If you didn't use the clutch locktabs you should have used thread lock in the clutch assembly IMHO (and M.E.D. / Morspeed's).
Threadlock on the flywheel bolt? I wouldn't myself but you've done it now. It's just that this is quite a high torque bolt and could easily be over stretched as a result. Maybe others always lock this bolt but I don't see the need, it's the taper that holds the flywheel once it's set.
Edited by Dan, 28 September 2007 - 09:38 AM.
Posted 28 September 2007 - 11:17 AM
Erm no. Ive used new lockwashers for the flywheel bolt, crank pulley bolt, and cam gear retaining nut. Everything else i just used what came off, as i wasnt aware new shouldered bolts should be used. I dont recall seeing any nylock nuts anywhere? When you say clutch locktabs, where do you mean exactly?Have you used new locktabs or new shouldered bolts or Nylocks in the relevant places? Or new pre-encapsulated bolts (like the oil pump bolts that come with special thread lock on them already?) If you didn't use the clutch locktabs you should have used thread lock in the clutch assembly IMHO (and M.E.D. / Morspeed's).
Yeah. I know a lot dont, but i always have. This is my first full engine build, from a freshly machined bare block, but ive been assembling short engines for a few years now with no major disasters. Ive always used threadlock on the flywheel bolt and taken the time to lap the tapers. My friend never does. He's had two fall off to date, destroying the flyhweel and crank. Im going to carry using it.Threadlock on the flywheel bolt?
Thanks for responses all, i like these informative posts more than the pedantic/sarcastic ones
