Painting My Roll Cage
Posted 26 September 2007 - 01:31 PM
Whats the best way of getting a nie gloss black finish?
I was just going to brush paint it but that'd probably give me a real bad finish.
So should i just get some rattle cans of primer, gloss black and some lacquer?
If so how many coats of primer, paint and laquer should i use and how long should i leave before adding each coat?
Posted 26 September 2007 - 01:33 PM
Posted 26 September 2007 - 01:35 PM
Posted 26 September 2007 - 01:37 PM
Posted 26 September 2007 - 10:31 PM
Posted 26 September 2007 - 10:48 PM
Posted 27 September 2007 - 08:17 AM
Posted 27 September 2007 - 08:37 AM
Or using a roller?
Edited by Teapot, 27 September 2007 - 08:37 AM.
Posted 27 September 2007 - 09:25 AM
Posted 27 September 2007 - 09:35 AM
Once you get used to spraying a tube shape it's not bad at all, just gotta keep moving,... If you Put 3-4 slightly heavier than 'light' coats on,.. you should get a nice, hard, smooth finish, then Buff it up with G3 rubbing compound.
Or just brush on hammerite
Posted 27 September 2007 - 10:03 AM
I suppose if it all goes wrong i'll learn from my mistakes and spray it instead.
Posted 27 September 2007 - 10:12 PM
I used some brush on grey primer and gave it a couple of coats and its come up loverly! Its stayed very smooth. There are some brush marks but i'v got some fine wet&dry and i'll jus give it a quick going over with that to smooth it off before paint.
I'm going to use johnstones smooth exterior gloss to paint it as my dad says it gives a decent finish on loads of surfaces. So i'll e doing that at the weekend so i'll let people know how i get on.
