I've been told different stories by them, from that it doesn't matter, or it's okay to use as clutch fluid to one who claimed I should be using DOT 3 instead!
But I've always used DOT 4 and that's what my owners manual and Haynes manual recommends. One local Mini Specialist stated that it should be okay so long as I flush all the old "Mineral" based brake fluid out first and basically don't mix the two. Trouble is he only stocked the same type stuff as everyone else and that's the "CARLUBE" synthetic based stuff.
I had a look around and I think I found the answer I was after via the Mini Spares site: -
Lockheed 250ml Brake Fluid link
Lockheed 500ml Brake Fluid link
Lockheed 1 litre Brake Fluid link
So from the claims and those prices I guess that's really what I want for my Mini then?
And if anyone has any tips on how to effectively bleed both the brakes and clutch on a 1990 Mini Cooper with a standard 8.4" discs and servo set-up, then it would be very appreciated.
Yes I know I can go and look it up and I do have a Haynes manual, but as this will be the first time I've ever carried out the task myself (with the misses helping), then I'd really like to hear about any problems or pitfalls that I might encounter. Especially from DIY beginner/novices like me?
Edited by taffy1967, 23 September 2007 - 03:43 PM.
