Project Student Loan+ebay= Project Ermintrude
247 replies to this topic
#136 tedmcedd
tedmcedd
  • 2,751 posts
Posted 29 August 2009 - 11:16 AM
I see whta you mean.... as long as its not simply a sheet of alloy with holes drilled in.... or a massive piece of mesh...
perhaps go for a works type one? the lightwieght ones they had on the monte's...
EDIT: i have a book somewhere about the works cars, it says in there what grill they used form some other BMC car to make the one above... ill have a look...
Edited by tedmcedd, 29 August 2009 - 11:18 AM.
#137 custodia
custodia
  • 330 posts
Posted 10 September 2009 - 05:04 PM
Right i've been quite busy recently and things are progressing well. The grill is on, then had to rewire the spots due to the fact that i put the wires through the slam panel forgetting that the bonnet shuts on it! Rookie mistake!!
Breather system is in place along with the wiper assembly and clutch assembly. Rear parcel shelf is finally secured along with rear lights, fuel tank and fuel pump fitted.
Dash almost finished with switches and vents. Jst needs spraying.
The plan is to have it running within the next seven days!!
Pics to follow soon
T
#138 custodia
custodia
  • 330 posts
Posted 11 September 2009 - 02:19 PM
Front end for now.
Attached File  P1010242.JPG   90.92K   24 downloads
Fuel pump in
Attached File  P1010245.JPG   68.06K   9 downloads
Breather system and braided brake hoses in.
Attached File  P1010244.JPG   76.86K   13 downloads
Engine bay almost complete. just needs wires hiding and cleaning up a bit.
Attached File  P1010243.JPG   89.91K   83 downloads
Dash almost done
Attached File  P1010246.JPG   75.77K   68 downloads
:thumbsup:
#139 tedmcedd
tedmcedd
  • 2,751 posts
Posted 11 September 2009 - 10:47 PM
looks amazing!
engine bay is so neat! love it!
you can't see your numberplate though... lol
#140 custodia
custodia
  • 330 posts
Posted 18 September 2009 - 03:10 PM
looks amazing!
Thanks ed, the number plate is an issue which i am trying to resolve but at the moment it is quite far down on my list of jobs as im going back to uni on sunday so want to get as much of the wiring finished as possible.
On the note of wiring, grrrr is all i can say. although all the lights in the dash now work but knowing not alot about electronics makes for a steep learning curve and slow progress.
Tim
#141 custodia
custodia
  • 330 posts
Posted 28 September 2009 - 07:18 PM
Have currently popped home for a few days so progress is back on. Doors and boot all finished and on along with most of the extra fittings. Forgot how annoying putting all the door mechanisms back together can be. Many c clips flying through the air.
Will be offering up and fitting the door cards using riv nuts tomorrow so hopefully more pictures soon.
T
#142 custodia
custodia
  • 330 posts
Posted 29 September 2009 - 07:38 PM
Slow day today. Got all the door cards drilled and ready, put in all the riv nuts. started screwing the panels in place. got to the last nut and bang goes the rivnut in the door panel!! grrr
Ended up drilling and then finally chisseling the bolt out then replacing the nut and finally getting them in.
Dash sprayed
Attached File  P1010248.JPG   80.21K   31 downloads
Makralon windows cut out and in place using sealed rear seals instead of opening.
Attached File  P1010249.JPG   66.42K   16 downloads
Doors finally finished
Attached File  P1010250.JPG   69.78K   7 downloads
Door panels all drilled and ready
Attached File  P1010251.JPG   71.52K   18 downloads
Door handles on
Attached File  P1010252.JPG   77.97K   9 downloads
Mechanisms all back in (Finally)
Attached File  P1010253.JPG   81.21K   11 downloads
Rear almost finished bar exhaust
Attached File  P1010254.JPG   78.6K   19 downloads
Passenger Door panels and wing mirrors on.
Attached File  P1010256.JPG   78.05K   50 downloads
Hopefully finish the doors tomorrow and get all the fuel pipe and battery cabling sorted and secured.
Time for a bulmers!!
T
#143 tedmcedd
tedmcedd
  • 2,751 posts
Posted 30 September 2009 - 02:35 PM
love it!! like the all blue dash and insides! mmmm!
#144 daemonchild
daemonchild
  • 2,341 posts
  • Local Club: Unknown
Posted 30 September 2009 - 02:39 PM
I'm liking the engine bay mate!
Explain again what you've done to get the heater pipes through the bulkhead please - that looks rather neat. :(
#145 george91
george91
  • 883 posts
Posted 30 September 2009 - 10:37 PM
This is coming together really well it looks sweet, and i love the colour. :lol:
Also just out of interest where did you get the door cards from?
And what sparco seat are they?
Edited by george91, 01 October 2009 - 01:45 PM.
#146 custodia
custodia
  • 330 posts
Posted 02 October 2009 - 08:19 PM
Hi there. Thanks for the comments.
In response i first cut two holes through a piece of rectangular aluminium that were just big enough for the brass plumbing fittings to fit through but not the securing washers that tighten up on them. This plate was then mounted to the bulkhead using industrial sealer and then the holes drilled through the bulkhead. Take the securing nuts off the brass fitting. Slide it into place and then put the nuts back on each end and tighten them up.
I believe the fittings are mainly used on internal plumbing and neumatic systems for securing lines through steel plate and walls. Hope this helps.
Tim
#147 custodia
custodia
  • 330 posts
Posted 02 October 2009 - 08:23 PM
This is coming together really well it looks sweet, and i love the colour. :(
Thanks for the comments. The door cards are made from aircraft grade aluminium and the material was origionally purchased from a pilot in scotland who was going for a two year tour to afghanistan and was selling off his unfinished mini project in parts so all i had to do was finish off the edges and cut the remaining holes out. The seats if i remember are sparco sprint v's. They are quite comfy and look great but are quite narrow.
Tim
#148 custodia
custodia
  • 330 posts
Posted 02 October 2009 - 08:36 PM
Got a bit more done today. Feels like i spent most of the day putting spiral band on the wiring going to the back of the car puts it was worth it.
Wiring has again been the order of the day but we are getting there slowly.
On the theme of tidying the engine bay up a bit more some extra electrical gromet fixings were added to tidy up the wiring by the wiper motor.
Battery cables were finished and are now in place running through the car to the cut off switch and then into the engine bay to the starter motor.
Holes drilled
Attached File  P1010257.JPG   80.32K   11 downloads
Fixings attached
Attached File  P1010258.JPG   77.45K   7 downloads
Wires insulated and through.
Attached File  P1010259.JPG   76.33K   14 downloads
Cut off switch mounted by drivers seat in 6mm ali with riv nuts securing to cross member.
Attached File  P1010260.JPG   82.37K   23 downloads
As my final project briefing is on monday i have to head back up to coventry tomorrow so i do not know when the next update will be. But im addicted now so hopefully will be able to get a weekend off soon and get back home in the garage.
Tim
#149 Philbo
Philbo
  • 17 posts
Posted 02 October 2009 - 09:10 PM
This is lookin really good mate, Keep it up.
Cant wait to see it finished.
Phil
#150 g111mds
g111mds
  • 432 posts
Posted 03 October 2009 - 09:16 AM
nice project you have. Really like the blue and white colour combination as well!
Jamie
