Engine/block related:
How To: Change the engine steady bushes
List of Cams and Timing figures etc
How to Guide: Fitting pistons to conrods
Clutches, The Differant Types Used
Video: Inside a combustion chamber
What Size Is Your Engine?
Gearbox related:
How To: Identify the TPM of your speedometer
How To: Removal Of Idler Gear Bearing In Transfer Case
How to video Guide: Removing the nose bearing race
How to Guide: Gearbox rebuild
Ratios, Final Drives and tyre sizes
How the Gearbox Works
Cylinder Head related:
Valve Sizes
Compression ratio's
Fuel and exhaust related:
Lambda Sensor Voltage
Petrol To Use ??? Leaded Or Unleaded ???
Leaded To Unleaded Conversion
Ignition related:
Matt's Megajolt Guide
Wiring for coil on electronic ignition
Cooling related:
How To: Change A Radiator
Is Your Car Over Heating?
Misc:
No synthetic oil in classic minis?
A series engine numbers
Having problems with SPI Single Point Injection
What Spec Is Your engine??
Whats the most Powerful Metro Engine?
How To: Check Your Oil
Stages of Tune for a Mini Engine
Which Starters Motors work with which Flywheels
Detailed Engine Bay Guide
Should I Connect Crankcase Breather to Carb?
Contents Of Engine Faqs
Jammy
, Sep 19 2007 03:57 PM
No replies to this topic
