Speedo/clock Casing Removal Help
Posted 15 September 2007 - 04:36 PM
Posted 15 September 2007 - 04:40 PM
Posted 15 September 2007 - 04:43 PM
Posted 15 September 2007 - 04:45 PM
I only need to take the casing off to fit and measure up new dash cover, would rather not take the whole lot out, any other ideas, if I get a mate to pull it off will it break?The outer main plastic housing (bit your stare at while driving) dose pull off. But I always just unbolt the lot from the engine bay.
Posted 15 September 2007 - 04:47 PM
Its the grey plastic surround which covers the 2 clocks...reckon someones glued it on hahaThe clock surround does just pull off. Is it the surround your trying to get off or are you trying to remove the clocks?
Mines screwed on :S found that out when i swapped a grey one for a black one.
Posted 15 September 2007 - 04:49 PM
Posted 15 September 2007 - 04:50 PM
