998 Turbos
70 replies to this topic
#61 D1k1m4y
D1k1m4y
  • 217 posts
Posted 29 March 2010 - 08:17 PM
worth getting or is it nackered?
#62 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 30 March 2010 - 06:26 AM
Who can tell from a picture ?
#63 D1k1m4y
D1k1m4y
  • 217 posts
Posted 30 March 2010 - 11:05 AM
what is there to look for that shows wear and things and where can i buy a rebuild kit from?
#64 simdhillon
simdhillon
  • 288 posts
Posted 05 May 2010 - 03:24 PM
There seem to be a few people interested or doing this conversion, so I thought that I would offer some advice from my own experience of building numerous 998 turbos.
firstly, see here for my latest conversion As you can see you need no engine mods and it all holds together, done 1000 miles now, no problems http://www.twin-turb...IN_20_HOURS.pdf
This used a T2 from an R5 GT turbo, this a great all round turbo for the 998, it won't boost efficiently over about 12psi, and will make a maximum of around 140bhp.
Other turbos I have used include the T3 of a metro and a GT17. The GT17 will make bags of power (160 or more I suspect) I have 155bhp and 1/4 mile times to prove it!. The T3 is a pile of junk, old technology, high inertia and enormous. The T3 will work and make 140 bhp easy, if not more but at the expense of driveability, you will not get boost below 4k, ok for track use, but little else.
Edit: I put 100 miles when it should have been 1000.
can this conversion be done on a 1275???????
#65 Wil_h
Wil_h
  • 3,244 posts
Posted 05 May 2010 - 04:52 PM
everything is the same whatever size the engine, except the cylinder head. you need a cylinder head with the chambers enlarged to drop the CR.
#66 Luipolly
Luipolly
  • 28 posts
Posted 26 May 2010 - 11:03 AM
Hello, im quite new to the mini world and i do alot of bodywork but unfortunatley dont know much about the mechanics. I want to do a 998 turbo project, i have a standard 998, what exactly in full would i need and roughly how much will it cost? Cheers
#67 Sleepy Stu
Sleepy Stu
    formerly Stewart_GT
  • 2,564 posts
Posted 26 May 2010 - 11:13 AM
Hi and welcome to the forum. Firstly have a look through all the threads on this site and most of you questions will be answered.
Next have a look here
Clicky
for more information on how Wil turbo'ed his 998 and also some of the modifications you should be making to the engine.
And finally check out the turbo minis forum which has a wealth of information.
Turbo Minis forum
Edited by Sleepy Stu, 26 May 2010 - 11:14 AM.
#68 Luipolly
Luipolly
  • 28 posts
Posted 27 May 2010 - 08:20 AM
Ok thanks alot for the help mate, apprecitated :P
#69 Luipolly
Luipolly
  • 28 posts
Posted 11 June 2010 - 09:15 AM
would this head be ok for a turbo conversion?
http://www.minisport...nder_Heads.html
#70 Wil_h
Wil_h
  • 3,244 posts
Posted 11 June 2010 - 09:22 AM
If it;s a 12G295 and has 28cc chambers then should be ok. the thing I would say is speak to Turbo Phill, as you'd be better spending the money with him and get a head that will definately be ok.
Generally heads, turbo or non-turbo, are all the same. The main differance in the A-series head is that you need enlarged chambers and good quality exhaust valves. I'm not sure what Phill does, but the exhaust valve guides can be reemed over sized to reduce the chance of the valves 'nipping up'; a common occurance.
#71 simdhillon
simdhillon
  • 288 posts
Posted 06 July 2010 - 09:01 PM
where do you get all the piping from??? and what cylinder head would you use for a 1293??
