998 Turbos
#16
Posted 06 October 2007 - 07:12 PM
#17
Posted 07 October 2007 - 02:59 AM
#18
Posted 07 October 2007 - 10:26 PM
#19
Posted 08 October 2007 - 12:10 AM
The Metro used a blow through turbo so the difference is the carb is air tight to stop the boost blowing petrol out in to engine compartment.
It used a Hif 44 that looks almost standard except for....
rubber seals on the throttle spindle
no crank case ventilation connector pipe
all ports are on the plenum mating face, where they'll be fed boost pressure, except for the fuel inlet and anti run on valve pipes.
there's a groove round the top of the dash pot that takes a clamping band to secure the damper and, originally, the carb was held together with anti tamper screws.
#20
Posted 08 October 2007 - 11:37 AM
Once the gaskets and hoses are all in places and its all bolted up i cant see any reason why i wouldn't be sealed.
#21
Posted 08 October 2007 - 12:20 PM
You probably could seal the carb and feed boost pressure to the float chamber but it'd be much easier with a Hif. Have you got the Vizard A series bible? It has a decent section on how the Turbo Metro carb was made boost sensitive which is another issue you'd have to sort out.
Edited by Ethel, 08 October 2007 - 12:21 PM.
#22
Posted 08 October 2007 - 10:10 PM
Is this carb good for anything?
#23
Posted 13 October 2007 - 12:27 AM
#24
Posted 13 October 2007 - 12:42 AM
#25
Posted 14 October 2007 - 06:39 PM
Is that an rs turbo intercooler you used wil.
Yes it is.
Yes it's a H6, if it's 1 3/4" a bit big for a 998 I'm afraid.
Not if it's s turbo though. The 1 3/4" carb works fine on a 998 turbo.
#26
Posted 14 October 2007 - 06:43 PM
Yes it is.Yes it's a H6, if it's 1 3/4" a bit big for a 998 I'm afraid.
I accept that, I meant in response to is it any use for anything - since Tom has a normally aspirated 998 at the moment.
#27
Posted 14 October 2007 - 10:18 PM
#28
Posted 02 January 2008 - 08:39 AM
#29
Posted 02 January 2008 - 10:33 PM
Can I try this configuration with a HIF38 and a 12g940 head???
Edited by FailleARQ, 02 January 2008 - 10:33 PM.
#30
Posted 03 January 2008 - 08:02 AM
Yes the 38 could be made to work, but it won't be a simple bolt-on like the turbo version of the 44 is. The main problem is that the plenum is for a 44 so won't fit. You'd therefore either have to make a new plenum with a suitable rstrictor ring, or be clever about where you got your float-bowl pressurising signal from.
