Spraying
Posted 09 September 2007 - 11:19 PM
Posted 10 September 2007 - 01:35 AM
Posted 10 September 2007 - 07:38 AM
i always use 600 grade wet +dry on solid colours and 800 on basecoatsWhat grade wet and dry do i use in between coats of paint.
Posted 10 September 2007 - 09:02 AM
Posted 10 September 2007 - 03:38 PM
just wait till it was back of the finger dry then apply the laquer
Posted 10 September 2007 - 08:06 PM
Posted 13 September 2007 - 02:54 PM
DON'T RUB DOWN INBETWEEN COATS! unless it's a solid gloss and you're letting it dry COMPLETELY between coats. You will only need to flat between coats if you have not prepped properly.
My car was preped 100% properly, I then put on the primer waited 24 hours rubbed it back a bit with 800 grit wet and dry left it for 24 hours, wiped away all the dry excess, then apply a good coat of colour, wait 24 hours rub it down a bit with 1200 or 1500 wet and dry, leave for 24 hours get rid of excess, then if it needs another colour coat repeat the last step if not time for the lacquer. I dunno if you can tell when a car has been painted at home by someone that isn't 100% sure of what to do but you can tell because the final finish feels like orange peel. None of that on mine, The finish is perfect, just what i wanted. SO DON'T TELL ME YOU SHOULDN'T RUB IT BACK INBETWEEN COATS OR BEFORE LACQUERING. IT WORKS WITH MY METHOD AND I GOT THE METHOD OF A CAR SPRAYER!!
Posted 13 September 2007 - 05:11 PM
I have no doubt the finish you have achieved is first class, but there are always ways of improving the general finish.
Pete
Posted 13 September 2007 - 05:35 PM
Anyway thanks to you both for the advice yesterday and as soon as I can pluck up courage I'll post before and after pictures of my first ever effort at body repairs.
Posted 13 September 2007 - 05:39 PM
Posted 13 September 2007 - 05:51 PM
Posted 17 September 2007 - 08:17 AM
Well, I feel like a tennis spectator, look left, look right, one says do, t'other says don't, but I'm sure you're both right in your own ways. On the paint aerosol can I just got at Halfords it says it's important to use 1500 wet & dry before lacquering because the paint has to be matt.
Do exactly that. I didn't use a metallic paint so you can get away with rubbing it down inbetween coats! Just dont rub too hard, you only want to go over it quickly and make sure you use plenty of water to do it.
Posted 22 September 2007 - 11:11 PM
Asking for micro blisters in the future.
At work I use 320 paper to flat primer for solid colours, and if prep is good and paint goes on nicely, looks fine.
For basecoat metallic I flat primer with anything between 600-1200 paper also depending how good prep is.
Definately dont flat basecoats between coats. The only time you should be dry flatting between coats of metallic base is if the edges of the primer are showing through, imperfections or you have a small reaction in the paint going on. But this should be flatted with 1500 dry ideally.
Definately make sure your last coat of base is not flatted before laquering. It will look an arse.
Posted 23 September 2007 - 10:25 AM
