Nissan Micra Engine Transplant
#106
Posted 16 April 2009 - 12:07 AM
#107
Posted 16 April 2009 - 09:18 AM
Also with the k11 1.3 do you think it would be possible to move it forward slightly and change the angle the engine sits to clear the bulkhead?
#108
Posted 16 April 2009 - 01:07 PM
Looks like a really good conversion, as you have cut the bulkhead with the k11 1.3 engine, can the brake master cylinder stay in the same place? Also im guessing its a cable clutch?
i see i would be using a k11 engine too. i dont really want to chop my car up either
#109
Posted 16 April 2009 - 06:26 PM
#110
Posted 16 April 2009 - 10:10 PM
#111
Posted 17 April 2009 - 07:05 PM
i think this would be a good engine for a mini, and you get a five speed box thrown in free !!!!exactly micras are cheap around here, and with some choice modds will put out 100 BHP to get that froma n a series means some very expensive mods , it just seems a nice cheapp conversion, ok not with the power of a vtec or redtop but if i do this it will be the most powerful car have driven (ashamed) so i dont need 160bhp
#112
Posted 18 April 2009 - 10:51 AM
Edited by richardsoniscool, 18 April 2009 - 10:57 PM.
#113
Posted 19 April 2009 - 02:37 PM
so..................andy001.
did u cut the subframe last weekend!?
how did it go? the first cut is always d hardest,,,,,,
No I didnt' cut it, lol
I've been hunting for a second subframe so i mock everything up. Once i find a frame, Ill be getting on
with it.
Yeah guys, the bulkhead needs cutting but it doesn't look too drastic.
#114
Posted 28 April 2009 - 01:21 AM
bigchief - what size (diameter & thickness) are the engine mounts you used for the Micra & Starlet engines?
the mounts are 2.5 inches in dia. it seems as though everytime i buy a batch of mounts they are of slightly different thickness from maybe 1.5 to 2 inches thick
#115
Posted 28 April 2009 - 01:28 AM
in alot of the earlier pics the wings are intact and ABSOLUTELY do not need to be harmed. i mentioned earlier that only one body mod is needed in the bulkhead, note that lateral strength is re-introduced by the stout piece of rectangular tubing between towers. by not making a box there are no corners for stresses to concentrate, just a semi circular indentation. i have recent pics that i'll elaborate with later in the weeki dont think i fillow in one of the above pics you have a bulk head box welded in and no inner wings, i thought you said there is no need for any body mods?\thanks
yes the brake master remains (not hinged booster though). cable clutch pulls from behind pedal. moving the engine forward will change driveshaft departure angles to wheels and induce weird gearchanges. a better idea is defn to tilt the engine forward about the axis of the axles. not too much because of sump issues, i find its safer to do the bulkhead.
100hp with is CG should be attained with a janspeed 4 2 1, de-cat and cold air intake.exactly micras are cheap around here, and with some choice modds will put out 100 BHP to get that froma n a series means some very expensive mods , it just seems a nice cheapp conversion, ok not with the power of a vtec or redtop but if i do this it will be the most powerful car have driven (ashamed) so i dont need 160bhp )))
the only advantage is tat its newer. the disadvantages include they are rarer, some parts are differen and the wiring is alot more difficult for a transplant. wudnt do it for 5 hp.is it worth while going for a later 1.4 (1348) engine and spending a bit more when you only get 5 more hp? just a thought, thanks mike
guys, theres alot of engine info for the micra, do's and don'ts and specs on the micra forums like 'micra sports club' and 'cisco's micra files'. have a good read
looking forward to hearing some good progress from u guys, later!
Edited by bigchief3679, 28 April 2009 - 01:44 AM.
#116
Posted 28 April 2009 - 06:53 PM
your using the orig mini radiator but what are you using as a fan?
cheers bigchief
#117
Posted 28 April 2009 - 09:14 PM
#118
Posted 07 May 2009 - 07:46 AM
Will start a thread...
Cheers for the inspiration Bigchief!
#119
Posted 07 May 2009 - 05:06 PM
Would prefer to use this engine at the moment to try and keep things a little simpler (no ecu to worry about).
Would like to get a set of bike carbs on it to give it a bit more, but thats another project.
Definatley want to give this a go.
Thanks Nige
#120
Posted 09 May 2009 - 05:34 PM
having trouble finding a sutible donor micra, have you/all tried any of these cars seems to be more of them
around (young chaves seem to crash them more)citroen saxo,vauxhal corsa,peugeot 106 any coments
please would be good
thanks andy
